need advice 98 dodge ram 1500 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Diesel Forums!
Dodge Caliber
Newbie Checkin! New to the forums? Introduce yourself here!
Place your Ad Here!
Old 12-29-2008, 12:27 PM
jesseh35980
Default need advice 98 dodge ram 1500
ok yall i'm new on this site and i need some help i just bought a 98 dodge ram 1500 with the 318 4 door well i knew the battery was dead and the starter was shot well replaced that and wasn't gettin fuel pressure so i replaced fuel pump but it continues to stale when you press to hard on the throttle but only while in drive in park it will red line with no problems i was recently told iot could be the tempeture seonsor but i have no idea how that could cause problems with the fuel+air mixture cause i beleives its flooding itsself out cause its slow to crank anyone have any idea?
Old 12-29-2008, 12:44 PM
DesertDog's Avatar
DesertDog DesertDog is offline
Vehicle: 2015 Ram 1500 4x4
Color: Silver metalic
Rep:37
DesertDog is on a distinguished road
Send a message via Yahoo to DesertDog
hello and welcome jesseh to the site
a good qualified mech could run a test and tell you wuts wrong with it alot cheaper than replacing alot of may be this part ideas...............
but wen you said that it wont hardly run wen in gear it could be yur EGR valve ,,, and or the mass air flo sensor is shot or dirty.
did yur fuel pressure come up wen you replaced the fuel pump?
and wen was the last time the fuel filter was changed
hope yu get it to workin
good luck
Old 12-29-2008, 12:49 PM
jesseh35980
Default yea
yea i have had a dignostic's run a few times and it shows up speed control sensor but i talked to the dealership and they said that sensor would have nothing to do with the way it runs i also thought the cat was stopped up so i unbolted the exsaust manifold and that didnt help either and i have no idea bout the egr
LYC79's Avatar
LYC79 LYC79 is offline
Trim Level: SXT CRD 2.0 / 2.8
Rep:426
Hi and WELCOME to the ForumZ jesseh!!! Hope you'll solve your problem.
Enjoy the board !
Old 12-29-2008, 01:00 PM
Yeah, I suspect the EGR valve is carboned, dirty and sticking. You can clean it (with a good quality carb cleaner) and make sure the lines to and from it are clear with some compressed air.
Sometimes, though, you just gotta replace them.
Old 12-29-2008, 02:13 PM
jesseh35980
well where would that be located on the truck i have never had to mess with one
Old 12-29-2008, 02:42 PM
DesertDog's Avatar
Rep:37
it will look like this
where at on dodge i dont kno, my guess would be the passenger side of engine , but i realy dont kno
and like maddog said you can clean them but be thurough about it they are a very picky part ,,,,,,,,
sorta like a woman.... if you dont treat them just right they...........
i better cool it women are on here.......
Old 12-29-2008, 02:50 PM
jesseh35980
i'll see how that works thanks guys
Old 12-29-2008, 04:17 PM
jesseh35980
well i cant find that sensor and my truck wont hit a lick any ideas?
Old 12-29-2008, 04:37 PM
jesseh35980
dealership says mine has a purge pump they didnt use EGR vavle on that year model...anybody ever heard of that?
