Old 12-29-2008, 11:40 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Default rear speaker question
I've been looking around for the speakers that I plan on installing in my Ram.
It's an '08 QC with the factory basic 4 speaker radio plus Sat.
I know the front speakers are 6X9. I've run into a contradiction on the rear speakers.... one place says that they're 5.25, another says that they're 6.5. Which place is correct? I'd hate to order the wrong ones.....
Thanks
Exco
Bill
Old 12-30-2008, 12:09 AM
DesertDog's Avatar
DesertDog DesertDog is offline
Vehicle: 07 Ram Mega Cab 4x4
Color: Black metalic
Rep:37
DesertDog is on a distinguished road
Send a message via Yahoo to DesertDog
can u take the old ones out and measure them ?
Old 12-30-2008, 03:03 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I just replaced mine with Diamond Audio 5 1/4" speakers. I believe it is a 6" speaker stock (it's an odd size). The speakers I used were not quite big enough to line up with the factory holes. Didn't want to drill new holes, so I cut a piece of MDF board to screw into the factory holes, then secured the speakers to the MDF panel.
Old 12-30-2008, 12:35 PM
Great idea, chithead...Mine are 5.25" stock.
Old 12-30-2008, 02:39 PM
Aggie 5.7's Avatar
Aggie 5.7 Aggie 5.7 is offline
Vehicle: 2008 Dodge Ram
Trim Level: Lone Star 5.7
Rep:12
Aggie 5.7 is on a distinguished road
I'd check crutchfield. They've never steered me wrong.
Old 12-30-2008, 03:06 PM
Excoastie's Avatar
Rep:1358
Crutchfield tells me that they're 6.5, OnlineCarStereo tells me that they're 5.25. As for my measuring my stock speakers, I was trying to avoid that, as I don't want to pull everything apart more than once....
Sounds like I'll go with 5.25, and do what chithead did, and make an adapter of sorts....
thanks everyone
Exco
Bill
Old 12-30-2008, 03:09 PM
chithead's Avatar
Rep:2078
Its not bad at all to pull the panel, TORX bolt for the handle, Philips screw behind the handle, and lift up on the panel. Be sure to disconnect the power window switch and remember to reconnect it before installing the panel back.
Old 01-08-2009, 07:33 PM
jeffssanders
A buddy of mine just had new speakers installed in his 07 Ram. He got 6 1/2" put in the rear doors. They just had to drill new holes to mount the speakers but they fit.
