Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
United Radio
Old 11-20-2008, 07:46 PM
tweety
Default Tach drop
Ok, posted this a bit ago but and or so WHAT makes my tach or the se tachs drop down to about 200-300 RPMs when sitting still in park or D? There seems to be no stumbling of the motor just the tach reading low.....
I have tried the turn key to run position press all the way to floor slowly and let return slowly then turn key off.. No difference seen. any helpful ideas or is it just something ewe learn to live with...?
06' ram 1500 quad "thunder road"
Old 11-21-2008, 11:55 AM
hh53helomech hh53helomech is offline
Gender: Not Specified
Vehicle: 2006 ram 1500
Trim Level: st
Color: inferno red
Rep:27
hh53helomech is on a distinguished road
I am having the same problem with my 2006 1500 V-6. The tach just drops to almost nothing and then goes back to normal when you start off again.
Old 11-21-2008, 08:57 PM
tweety
yes exactly but I have yet to notice that the motor actually runs at that low of RPMS ... Seems to be still idling just fine. sometimes it will drop and then return to normal 500 or so on my trk.
Old 01-12-2009, 03:10 PM
Trim Level: st
Color: inferno red
Rep:27
The engine seems to idle fine at the proper rpm but the tach does not indicate the correct rpm. I checked the electronic connections but found them tight. Does anyone know if this goes through the computer somehow?
