Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
United Radio
Old 01-08-2009, 04:49 PM
Jeffrey1089
Exclamation knocking noise in the front end
I have a 2002 dodge ram with 39000 miles on it. About 3 weeks ago the front end started to make this knocking noise when im at speeds from 0 to 25 then after 25 it stops. does anyone know what the problem is?
also when im on the high way and i hit speeds from 55 to 65 the truck vibrates really bad and smoothes out at 70.
Old 01-22-2009, 04:42 AM
DODGE_BOY1990
I have a 2000 dodge ram that has the same problum and i cant find it neather can a dealer
Old 01-22-2009, 09:23 AM
07USMC3.7L
Well, does the vehicle knock when you idle or just when your moving? Are you sure it is a knocking or more like a banging or what?
As for the vibration, my old Explorer did the same exact thing. So I spent a whole weekend trying to figure out what was wrong untill sunday night it dawned on me. Run your hand over the tires. be sure to feel for any large bubbles or warping. I can almost guarentee that you have a tire issue. I replaced the tire and problem solved. No more vibrations.
Old 01-22-2009, 09:23 PM
maddogmx502's Avatar
maddogmx502 maddogmx502 is offline
Vehicle: 03 Ram Quad Cab 1500 4X4
Color: White Out!!
Rep:12
maddogmx502 is on a distinguished road
If the vibration isn't a tire issue it might be a bad u-joint.
Old 01-22-2009, 10:20 PM
ph3nom3non03's Avatar
ph3nom3non03 ph3nom3non03 is offline
Vehicle: 2000 Dodge Ram 1500 4x4
Trim Level: SLT LARAMIE
Color: Intense Blue Pearl
ph3nom3non03 is on a distinguished road
yea just as usmc said check your u joints i have had complaints of this before but be sure to get your tires check'd out by a shop that can road force them to figure out how much vibration is coming off them also check your bearing and all your front end suspension sounds like the truck sat for a a long time with that kinda of mileage for an 02? so you may have spots of rust in your bearings and such that a tearing apart but repost on it and we'll further help you
Old 01-22-2009, 10:35 PM
Marcelo's Avatar
Marcelo Marcelo is offline
Vehicle: 2005 5.7L HEMI
Trim Level: SLT Quad Cab 4WD
Color: Flame red
Rep:34
Marcelo is on a distinguished road
Taking a look at the shocks is recommendable also. Many of the vibes come from a bad suspension.
