Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 01-11-2009, 10:23 PM
jpc1962's Avatar
jpc1962 jpc1962 is offline
Vehicle: 2002 QCSB 4.7L 2wd
jpc1962 is on a distinguished road
Thumbs up Pulling
The easiest way to diagnose a bad tire is to rotate the frt tires side to side. If the tire is the problem, the pull will either lessen or change the other way.
2002 QC 1500 4.7 2wd
Old 01-12-2009, 06:33 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
I still say it's the tires causing your problem, I agree rotate them, But rotate the from front to back. When you do side to side it's very hard on the belts in the tires and can cause them in a lack of a better word slip. This is what can cause tire issue's called radial pull. I suspect that this is whats going on with your tire's right now.
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 01-13-2009, 09:57 AM
Danstona Danstona is offline
Vehicle: 2005 Dodge Ram 1500 4x4 5.7L
Trim Level: Hemi Sport
Rep:35
Danstona is on a distinguished road
There is no difference when I engage 4 hi. Just thought I would let everyone know.
Old 01-16-2009, 08:32 AM
Rep:35
Well, I had my father in law swap the front tires from side to side.. and the pull to the right is gone. I do get a slight feel of a pull to the left now, but not always. I'm going to check the tire pressure as soon as I get home and can dig out my guage.
Old 01-16-2009, 10:17 AM
ph3nom3non03's Avatar
ph3nom3non03 ph3nom3non03 is offline
Vehicle: 2000 Dodge Ram 1500 4x4
Trim Level: SLT LARAMIE
Color: Intense Blue Pearl
ph3nom3non03 is on a distinguished road
my advice is rotate the tires and take it and have it aligned and be sure to get a printout thats readable to your standards there are a few different types because i work for a shop and have heard of other shops taking advantage of only setting the toe thats wrong especially if the caster and camber are out because like your vehicle has a pull the camber could be out in which they are adjustable along with caster too they will make a pull if they are out and the toe looks good. but get a alignment done i work a firestone and we have lifetime align they cost like 160 dollars but its worth it cause you can bring your car in 3x a week if you want even if you replace new front end parts you bring it in and get er done lol but good luck
Old 01-16-2009, 05:53 PM
Rep:35
Well, I had the tires swapped side to side, and it never cost me a thing for now. It seems to have corrected whatever was wrong... I dont want to get into moving the rears to the front for now though, as my front two tires are 40%TL and the backs are almost new.. abot 95%TL... so until we're out of the snowy months, I'm not spending money ($350/corner) to put new tires on the front, or move rears to front.
