Old 01-15-2009, 02:28 AM
acosby
Question 2008 CB Install
I'm brand spankin' new to the world of electrical work in Dodge trucks. I've owned Fords prior. I know, I'm sorry--I was young and stupid. I'm now the proud owner of a 2008 Dodge Ram 1500 quad cab.
I'm trying to figure out how to hook up a CB radio to the fuse box. I know where the fuse box is, and can't find a secondary fuse box in any of the "regular" places. I can't find a route through the firewall.
So, is there an easy way to hook up to a 12 volt fuse from inside the chassis? I've seen several cable input boxes, but they're not colors I'm used to. Alternately, has anyone installed a CB radio, and if so would you be willing to walk a newbie through it?
Thanks in advance.
-Alex.
Old 01-15-2009, 07:21 AM
Rep:4072
Default Re: CB install
Hello. New to this forum, but not new to Dodges or CB's, but the only way I have found that will work is to go through your cigarette lighter, that allows access for the wiring into the cab. My problem, now that I want to put my radio in my truck, is what to mount it to that keeps it in reach, but not in the way???
As for wiring it, in the old days, you could just hot wire it to the battery and call it a day (so long as you remember to shut it off when you are done!), but now that you have to be an electrician to work on today's vehicles, not so easy. There has to be an accessory fuse somewhere that would work for this purpose. I am just now getting around to looking into this for myself. I will have to do some checking in my fuse box (I have an '08 Ram, also), and get back to you on that. Just funny I saw this post and also had similar questions along the very same lines.
If you figure it out before I do, let me know, but a fuse/fusible link would be advisable, if nothing else, to protect your equipment.
Old 01-15-2009, 10:11 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
People, the best thing to do is get a DC Buss with fuses and attach it under the steering column. This will allow for your CB and future accessories. Remember to size it according to what you have planned + a little extra. Run a Red and Black wire into the engine bay through either a existing grommet or a completely new 1/2 inch hole that you get to drill yourself .... Make this neat in appearance and out of the way of other wiring. This will keep the interference of other electrical components away. You now have a terminal station / fuse block to run your CB Radio and all other goodies you may want to put in the cab............Then again why not just use the extra 12v plug in the dash??????
Old 09-13-2009, 09:42 PM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
Congrats on the 08... ok first if you Hack into any wires,fuse set up and you have an electrical issue dodge will most likely no cover the issues. If you need
a 12 volt source look at the trailer brake connection the factory supplied on your truck. Go to Say Napa and buy a Dodge trailer brake provision plug.
You will have a ground and a 12 volt supply with a clean hook up. If there is ever an electrical issue just unplug the provision plug and there is no indication of owner alternations of the electrical system. The provison plug is located on the driver side by the parking brake, you will see a plug on top of the main wire harness connection block. My plug is blue in color (07 ram 1500)
The 12 volt is hot all the time.
Thanks in advance.
-Alex.
Old 09-13-2009, 09:47 PM
Color: grey
Rep:12
Nothing wrong with Fords....I had several Fords that had well over 120,000 miles on them. This is the first Dodge for me....Time will tell.
Thanks in advance.
-Alex.
Old 09-13-2009, 09:57 PM
Rep:4072
Thanks, MRRMX, and you know, I still haven't installed that darned radio, but your thought gives me an idea, appreciate the info!
Old 09-13-2009, 11:23 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
Cajundodge, here is a way to mount your CB. This is what I am going to use.
CB mount.
http://www.genosgarage.com/prodinfo....CB_MOUNT_0305W
Antenna mount
http://www.walcottcb.com/firestik-mk...kit-p-307.html
Old 09-14-2009, 01:03 AM
MikeD MikeD is offline
Vehicle: 2009 Ram 1500 Quad Cab
Color: Stone White
Rep:13
MikeD is on a distinguished road
Cajundoge,
If you decide to go with the mount from Geno's Garage, I have one that I'd like to sell. I bought it to mount my ham radios and after they assured me that it would fit my '09 QC, it won't. The bolt holes are in all the wrong spots for the new interior style.
Old 09-14-2009, 01:29 AM
Rep:4072
Originally Posted by MikeD View Post
Cajundoge,
Yeah, that looks like what I am looking for, just hard to tell from the picture, that would be a fixed mount, correct and it bolts to the floor? PM me with price and details, please.
Old 09-14-2009, 11:44 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
any reason that you can't go down to radio shack and get a plug for the cig lighter? They're fused, they're easy to connect to your radio, and it's almost hassle free.
True you might have to get a bit creative running the wires, but I'm sure you'll figure something out....
good luck
Exco
Bill
cb radio, electrical, fuse, ram, wiring
