Aftermarket Radio Help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 01-22-2009, 06:49 PM
ShanghaiPaddles's Avatar
ShanghaiPaddles ShanghaiPaddles is offline
Vehicle: 2001 Dodge Ram 1500
Rep:18
ShanghaiPaddles is on a distinguished road
Default Aftermarket Radio Help
So I'm trying to install an aftermarket cd player into my 2001 Ram 1500. I connected all the wires and plugged in the wiring harness and went to turn on the radio. But it didn't work. I double checked my wires and all were fine so I took a test light to the wires and found that both the positive and the negative speaker wires are getting power. WTF? A friend said that it was because of the stock amp installed so I need to know what to do to make the cd player work. Any and all help is awesome.
-Kevin
Old 01-22-2009, 09:01 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Not sure if this helps but might double check:
Constant 12V+ Red
Switched 12V+ Red/White
Ground n/a
Illumination n/a
Dimmer Orange/White
Antenna Trigger Yellow
Antenna Right Front
Front Speakers 6" x 9" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 5 1/4" Side Panels
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
If I remember correctly, the amps were on the speakers if you had the Infinity system in those trucks.
Old 01-22-2009, 09:26 PM
Rep:18
Thanks for posting the diagram, I'll double check tomorrow when it's not so cold out. You are correct, the speakers are on the speakers.
Old 01-22-2009, 10:26 PM
chithead's Avatar
Rep:2078
Cool let us know how it turns out.
Old 01-23-2009, 01:40 AM
bwoodredkneck's Avatar
bwoodredkneck bwoodredkneck is offline
Vehicle: 2001 dodge ram 1500 4X4
Rep:24
bwoodredkneck is on a distinguished road
Send a message via MSN to bwoodredkneck
on my 01 i had a alpine toutch screen and i had to run the 12v power to my fuse box
Old 01-23-2009, 10:55 AM
chithead's Avatar
Rep:2078
I read that the 04-08 Rams do not carry enough voltage on their constant (pink wire I believe it is) to provide a good power for aftermarket radios, but had not heard if this was the case on any previous models.
Old 01-23-2009, 04:24 PM
Rep:18
So I haven't checked the wires yet, but last night I tried one more time to get it to work and the deck turned on and everything worked: radio, cd, aux but there was no sound coming out of the speakers. No matter how loud I turned it up or which source I was on, there was no noise or static or anything. This is just confusing the hell out of me.
-Kevin
Old 01-23-2009, 08:21 PM
Rep:24
some times the wire colors are diffrent you mite have to actually read the text on the wires
Old 01-26-2009, 03:30 PM
chithead's Avatar
Rep:2078
Hmmm... Definitely is a weird diagnosis. What kind of radio is it?
Old 01-27-2009, 12:20 AM
loudrango's Avatar
loudrango loudrango is offline
Vehicle: 97 Ram,96 Ram,98 rango,01 rang
Trim Level: ram slt -rango r/t
Rep:64
loudrango will become famous soon enough
your friend is right.it is to do with the factory amp.this is a big issue in rams,'rangos,etc that have the factory infinity setup.most i know bypass the factory amp and add a small aftermarket one in its place.
2005 IASCA Stock 3 World Champion
2004 IASCA World Finals 4th place
