Old 01-27-2009, 12:43 AM
ShanghaiPaddles's Avatar
ShanghaiPaddles ShanghaiPaddles is offline
Vehicle: 2001 Dodge Ram 1500
Rep:18
ShanghaiPaddles is on a distinguished road
Originally Posted by loudrango View Post
your friend is right.it is to do with the factory amp.this is a big issue in rams,'rangos,etc that have the factory infinity setup.most i know bypass the factory amp and add a small aftermarket one in its place.
Do you know how to bypass the amp? I getting to the point where I want to go to Best Buy and have them install it because this is turning into a bigger headache than I want.
Old 01-29-2009, 07:13 PM
Rep:18
Well, I said f**k it and dropped the truck off to have Best Buy install the radio and amp. $135 I didn't want to spend, but it's easier this way. I sure hope they can figure out the speaker issue. Thanks to everyone for their help.
-Kevin
Old 01-30-2009, 12:44 AM
Rep:18
So I just picked the truck up, and I don't know what they did, but it works just fine. Couldn't be happier.
Old 01-30-2009, 12:15 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Well good. I know more about the newer ones than the 90's models unfortunately. Gotta have tunes though! Glad you got it fixed!
Old 02-01-2009, 11:11 PM
jrush78 jrush78 is offline
Vehicle: 2000 Dodge Ram Quad Cab
Color: Blue
jrush78 is on a distinguished road
I have a similar problem. I can get audio some what but I do have to have the blue amp wire from my aftermarket stereo hooked up to the blue wire from the harness. My problem is the sound is all WRONG.. in the front only the driver side door speaker is working and it sounds really drowned out and all treble. The passenger side door speaker get nothing at all, nothing from the tweeters either. The back two door speakers sound ok as long as the stereo is set to normal any type of eq setting custom or like ROCK and they have too much bass.. Hopefully I can find something on these forums in a search or others know what my problem is. Maybe I will try calling BestBuy tomorrow to see if they can direct me without having to take it in. Too bad they didnt tell you what they did.
Old 02-08-2009, 08:05 PM
2004Hemi
Default 2004 Ram Alpine install.. same problem
The stereo hooks up everything works no sound. To bypass the amp is the only way to get it to work??
