Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
MOPAR DECALS
Old 01-24-2009, 01:24 PM
truegrit truegrit is offline
truegrit is on a distinguished road
Default 5.9L Cummins thrust bearing
Has anyone ever heard or had the thrust bearing breaking in an '06 Cummins?
My truck has 101,000 miles on it. The dealer offered to replace the engine with a remanufactured long block if I split the cost with them. I had replaced the transmission 2 days before and the general thoughts were that the transmission shop may have put the wrong torque convertor in and caused significant pressure on the end of the crank and cuase premature failure of the thrust bearing with excessive wear. Then I would have been liable for the entire cost of the dealers repairs, $18,000 to $20,000. So I moved the truck to a different shop (Dynomite Diesel, Monroe, WA) to do all the work. This shop pulled the engine and dropped the pan and found the thrust bearing to be broken. Has anybody ever heard of this problem with only 100,000 miles on a Cummins?
Greg
Old 01-24-2009, 05:23 PM
Smokin'Ram Smokin'Ram is offline
Vehicle: 2002 Ram 2500 CTD
Trim Level: SLT quad cab
Color: silver
Rep:12
Smokin'Ram is on a distinguished road
I have never heard of this before. I would tend to agree that somebody did something wrong to cause this. My Neighbor is a farmer and he had a '90 dually 4x4 cummins with 340K when he traded it in on an '05 dually and never touched the engine. Ive seen him do things that should have destroyed that truck but didnt! Good luck with the truck.
Old 01-24-2009, 10:18 PM
I've never heard of a thrust bearing going bad with that few miles. If the torque converter was the wrong stall speed I don't think it would cause a thrust bearing failure but if it was installed wrong, it could cause excessive torque shock which isn't a good thing for any bearing on the crank.
