Exhaust help! - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 > Exhaust
Exhaust 5.2L Wxhaust Discussion
Old 01-29-2009, 12:18 PM
StevoSRT's Avatar
StevoSRT StevoSRT is offline
Vehicle: 2013 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
Color: White/Gold
Rep:40
StevoSRT is on a distinguished road
Thanks for the kind comments, StevO! You are correct. The "X" or crossover pipe helps to scavenge exhaust efficiently and equalizes the exhaust pulses. It also helps in maintaining low end torque.
Hot exhaust gas, as it cools in the pipe, wants to "crossover" as the length of the pulse increases. Finding the right spot for the crossover pipe is important.
One fool proof way to do that is after you have the duals on without the crossover, paint the inside of the pipe behind the cat with some paint back towards the mufflers. I'd say 12 to 18 inches should be enough. Run the truck for a while around town, do a few WOT blasts just for giggles and grinz, then get back under the truck to see where the paint has burned off...where it ends is a good place for the crossover as the gas has cooled to the point where it wants to crossover.
Hedman, JBA, SLP and Doug Thorley are all firms you should google up and search for applications.
I've used SLP, JBA and Thorley headers before. They have really good quality stuff.
With any header, get a set of Stage 8 fasteners. Once they are in and torqued to the correct spec, when you add the clips, they never back out! Also, get a good set of gaskets. Summit used to carry a line from Russell Pressure Master Seals which were outstanding gaskets. Combine a good set of gaskets with the fasteners and you won't have to worry about leaks.
Interestingly enough, JBA is a California company so all their products carry a California Air Resources Board (CARB) emissions compliance certificate. Since CARB requirements are so stringent, most states recognize this certificate and grant reciprocity...meaning if it has this certificate, it meets or exceeds their emissions requirements and they won't consider your headers or other mods to be in violation of the emissions rulez in your area.
well if you wanna get all technical about it! LOL
very well written
Stevo @ DriveSRT:
http://www.drivesrt.com/news/2012/12/srt-owner-profile-steve-crisalli-white-plains-new-york.html
Old 01-29-2009, 04:25 PM
Well, I can't help it...LOL Thanks for the kind words.
I figured paintballproam could use the info in any event.
Old 01-29-2009, 08:36 PM
paintballproam
Went on the highway with it today and realized that i may love the bottom end power on the ram, but it has like no top end. I raced my friends 4.3l v6 blazer from a roll, and lost. I tried to get it up to 100mph and it took FOREVER.lol
would doing the full exhaust, the intake, and programmer make a big difference?? I know i know, my evo is my go fast car, not the ram, but still.lol
off topic, but im sure maddog can answer this, Driving today, my friend had me pull over and told me that i had a hose dangling under my truck, looked under it and there is what looks like an egr valve bolted to my front axle on the passenger side. There is a 5/16" hose coming off it, with a plastic barb in it, like so you could connect another hose to it. Where does this go and what is it???
Old 01-29-2009, 10:42 PM
paintballproam
Just thought of something else, you said not to go more than .25" bigger than stock, well, lets say the stock system is 2", just so its easy to figure out. If i ran dual exhaust, with 2" pipes, then wouldnt that have twice the flow capability and half the back pressure?
Also, i saw a bolt in magnaflow cat, its got pipes that bolt to the factory headers, then down to the cat that uses factory hangers, then a pipe that goes to the cat back. How would this, plus a supper 44 with dual outlet do?
Old 01-30-2009, 10:06 AM
StevoSRT's Avatar
Color: White/Gold
Rep:40
ill let the big guy answer this but no i do not believe that to be the case...
and as far as the MF's...if they were like my cars....they just are a drop in sorta thing that bolts right in no issues
Stevo @ DriveSRT:
Old 01-31-2009, 01:03 AM
paintballproam
i forgot exactly what it is, but the guy said its a vent hose for the case on the front axle, something like that, he said just fix it somewhere and make sure it stays out of mud and stuff
Old 01-31-2009, 01:09 AM
First, your dangly hose is the front transfer case vent. Just zip tie it up near the axle tube but don't kink it.
With respects to the pipe size, no it won't hurt your truck to go to duals as long as you have the crossover in it as that helps provide the backpressure you need to maintain low end torque.
The magnaflow cat and super 44 single in/dual out system would work great. That's basically what I have only I went magnaflow for the muffler.
Here's a vid of the system:
http://s10.photobucket.com/albums/a1...PICT0003-1.flv
About that top end..your engine needs more air and the stock intake won't provide enough. You just need to get a CAI on it and add a programmer.
