Old 01-29-2009, 03:25 AM
blackram1500 blackram1500 is offline
blackram1500 is on a distinguished road
Default Does anyone know.....
Filtration and separation of water from the fuel is important for trouble-free operation and long life of the fuel system. Regular maintenance, including draining moisture from the fuel/water separator filter is essential to keep water out of the fuel pump. To remove the collected water, unscrew the drain at the bottom of the Water-In-Filter (WIF) assembly located at the bottom of the filter separator
SO WHERE IS IT LOCATED ON THE TRUCK AND HOW OFTEN DO I DRAIN IT???
Old 01-29-2009, 06:35 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
I'm sure there talking about diesel trucks not gasoline. If you have a diesel it's located under your hood I think on the driver side.
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
