Old 02-03-2009, 09:34 PM
OLDTECH OLDTECH is offline
Vehicle: 2008 DODGE RAM 1500 QUAD CAB
Trim Level: BIG HORN SLT
Color: COOL VANILLA
OLDTECH is on a distinguished road
Question Extended fast idle - 2008 dodge ram 1500 hemi
When i start my truck the fast idle stays up to 1200 to 1400 rpm for approximately 2 minutes before falling to curb idle speed. This happens with engine cold or hot. Took to dealer. They contacted dodge technical assistance and were told there is no fix at this time and that condition is to be considered normal at this time. The fast idle would be correct with cold engine but not with hot engine. Has anyone out there had this problem and if so, what did you do? Thanks for any info.you might have.
Oldtech
Old 02-03-2009, 10:44 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
The fast idle can be lowered by pressing the gas pedal quickley, or by pressing the brake in hard and putting the vehicle in gear. The engine will reduce RPM before the Tranny will engage in gear as long as the brake is in all the way. This programming is built in to save the tranny........ All is NORMAL and to be expected. My last Toyota Tacoma had a freaking high idle that was the same in Hot and Cold climates. Sounded like the engine was going to blow up sometimes
Old 02-05-2009, 08:41 PM
Color: COOL VANILLA
Thanks for the info. I'll give it a try.
Oldtech
Old 02-05-2009, 09:25 PM
cerres cerres is offline
Vehicle: 2006 4*4 3/4 Quad, 5.9 Auto
Trim Level: SLT Big Horn
Color: Khaki
Rep:12
cerres is on a distinguished road
High idle is rather common. At start up, at low RPM, there's not enough oil being thrown onto the cylinder walls... high idle insures a sufficient amount of oil on the cylinders at start up, hot or cold...
If ever you have the opportunity to see the bottom end of an engine throw oil onto the cylinders at idle (they really do this via lexan windows in the pan or cameras mounted on test engines), you'd be shocked how little is actually getting to the cylinders!
Old 02-09-2009, 10:27 PM
Color: COOL VANILLA
Thanks for the input . As i noted before , i contacted the dealer about the high idle on hot start. They stated dodge knew of the problem and were working on a fix and deemed it normal until the fix was ready which i assume will be a reprogram of the ecm.. Also ,i have a 2006 charger rt with the same engine including mds. The fast idle drops to curb idle within 10 seconds of startup when hot and drops to curd idle within 20 seconds of a cold start. The owners manual for my truck states do not put into gear until rpm drops to curb idle or transmission damage will result. If you guys have seen anything in print that updates the owners manual please let me know where you found it. Thanks for your help.
Oldtech
Old 02-09-2009, 10:35 PM
Rep:62
Have you tried blipping the throttle to see if your RPMs will drop after?? When I push the brake in all the way and place the truck in reverse the rpms come down and the tranny then shifts into reverse. Just make sure that you have your foot on the brake or it will slam into reverse.
Old 02-10-2009, 05:15 PM
My Chrysler did this until they reflashed the computer. Startup idle speed was consistently at about the same RPM as you stated, hot or cold.
No problems now.
Old 02-19-2011, 07:19 PM
nixont nixont is offline
Vehicle: 2007 Dodge Ram
Trim Level: Lone Star
Color: Khaki
nixont is on a distinguished road
Does anybody know if they have a fix for the Ram yet? My 2007 Ram 1500 with a 4.7l does the same thing. It scares me every time i stick it into reverse. Fast idle starts at about 1200rpm regardless of the engine temp.
Old 02-20-2011, 05:32 AM
67Polara's Avatar
67Polara 67Polara is offline
Vehicle: 2001 2500 ext cab long bed
Trim Level: sport
Rep:77
67Polara will become famous soon enough
should i be worried that my ram doesnt do this, it hits 900 rpm's at most cold.
"I'm your huckleberry" (Doc Holiday)
Old 07-02-2012, 08:18 PM
maybz maybz is offline
Vehicle: 2007 Dodge Ram Laramie
maybz is on a distinguished road
just wondering if you ever solved the problem with the high idle on start up. My 07 hemi does the same
