Old 02-04-2009, 11:14 PM
sarguy01 sarguy01 is offline
Vehicle: 2009 Dodge Ram TRX4
Color: Inferno Red.
Rep:12
sarguy01 is on a distinguished road
Default The 2009 Thread!!
Post any random stuff about 2009's here.
-Anybody look at Ebay stuff yet?
-Does your truck shake slightly at idle?
2009 TRX4.
Old 02-06-2009, 11:21 PM
09sport's Avatar
09sport 09sport is offline
Vehicle: 2011 quad sport HEMI 4X4
Color: DWB
Rep:30
09sport is on a distinguished road
there are some of items on ebay for 09 I recently installed airaid cold air intake kit and sounds got better..as you commented it does shake at idle.. no idea about that I just ignore.. I have had the rattlling from right side(air filter side)which has been fixed from dealer shop.
2011 Quad Sport 4X4 DWSB HEMI
2010 Harley FLSTF Fatboy Black
2009 Harley FLTR Road Glide Black
Old 02-07-2009, 08:45 AM
Color: Inferno Red.
Rep:12
the consensus is it that shaking at idle is normal. have you seen the "fuel saver mode" come on in the EVIC yet?
2009 TRX4.
Old 02-08-2009, 01:11 AM
Big Country
I have kind of a strange one here. Ok, on the dipstick there are two humps down where you check the level of the oil. In between the two humps is the engraving of the "safe" area. When I check the oil on my new 09 Ram, it's all the way up to the bottom of the top hump on the front side and on the back is closer to the top of the line of the "safe" area. Anybody with an 09 check theirs lately? I want to ensure it's not overfull.
Old 02-08-2009, 08:35 PM
09sport's Avatar
Color: DWB
Rep:30
I have changed at 2,000 castrol gtx. it's filled little less than the top hump,, pressure is 26psi(at idle)~52psi(at 4500 RPM) since 2,500miles whn I start,, keep beeping with oil change due sign..
Old 02-09-2009, 01:40 AM
Big Country
There is a procedure to reset the oil change due chime. I can't remember it off the top of my head but your owners manual will talk about it. Has to do with turning the ignition to accessory or on and depressing the gas pedal 3 times within 10 seconds. I think there might be one other thing you have to do, but again, I can't remember exactly what that is.
