Truck dying- fuel pump? Please help :) - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-02-2009, 01:19 AM
Quadrider712
Default I am having the same problem!!!
I have a 96 1500... she has 144,000 on her. My fuel gauge reads empty at all times, and i have the same problem but mine wont even hit 2500 rpm without bogging down horribly. It actually sounds like it is being governed. I also have to lift my foot from the pedal to shift into any gear and its an auto, and i am feathering the gas. Any ideas any one?
Old 03-14-2011, 08:00 PM
Jac Tamez's Avatar
Jac Tamez Jac Tamez is offline
Vehicle: 2001 Dodge 2500 Quad Cab 4x4
Color: Desert Tan/GG Camo
Jac Tamez is on a distinguished road
I am having what appear to be fuel pump problems also. I installed an airtex pump today and it worked fine one time. The truck is now back to hard starting and once it does start, i need to keep the pedal to the metal for it not to shut off. I think im gonna get something like an airdog pump installed. anyone have any other ideas????
Old 03-17-2011, 08:25 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
if your having problem with those aftermarkets id go witht the OEM. the OEM's are what i allways go with. the truck i had before had 249,000 miles on its origional fuel pump. the dodge i have now has its origional fuel pump with 262,000 miles on it.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-17-2011, 12:00 PM
Rep:2946
if your gas tank is close to full, sometimes it is better just to unbolt the bed, disconnect some wires, buy a 12 pack of beer & invite 3 or 4 friends over & lift the bed off
Just make sure the fuel pump is the culprit, before you tackle it
Old 03-17-2011, 01:20 PM
Jac Tamez's Avatar
I read somewhere that the crank position sensor also causes starting/running problems. Does anyone know anything about that?
Old 03-17-2011, 01:23 PM
Jac Tamez's Avatar
Mine is a diesel. Am in the wrong part of the forum?
Old 03-22-2011, 08:01 AM
98redbull2's Avatar
Rep:52
my crank sensor got replaced by my boss at work before i baught it from him but i dont remember why he replaced it i think it was actin up on him, but he did allllways replace stuff that didnt need replaced just because he wanted too.
Old 03-23-2011, 10:05 PM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
hearing the fuel pump run doesn't guarrantee it's working. seen that a few times. need to make sure fuel pressure is in spec. once we know that, we can press on...
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
