Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
tonneaucovered.com
Old 02-24-2009, 12:01 PM
jcasey8379
Default Hard starting 02 cummins.
Hey guys! I drive a 2002 1500 with a cummins. Here's the problem, when I first start the truck for work every day, it literally takes 30 seconds of cranking it over before it starts. My first thought was that it wasn't getting enough fuel. Checked it out and the fuel pressure is perfect.
I had the deisel mechs at work look it over and they think it's something to do with the air intake heater (element?). They checked the selinoids that control the heater are not getting power.
My question is does anyone (hopefelly Dodge or Cummins techs) know what the problem may be? Or, does anyone know where to get a schematic of this sytem?
Any help is greatly appretiated!!
Old 02-24-2009, 12:35 PM
cerres cerres is offline
Vehicle: 2006 4*4 3/4 Quad, 5.9 Auto
Trim Level: SLT Big Horn
Color: Khaki
Rep:12
cerres is on a distinguished road
Casey, I need a little more information... where you are, would help greatly
Old 02-24-2009, 12:56 PM
jcasey8379
I'm in Minneapolis. The problem happens in temps between -10F and +30F.
The block heater is working by the way....
Old 02-24-2009, 01:23 PM
Color: Khaki
Rep:12
thank you for your response. Okay, if the manifold heater is working and the engine is difficult to start with 40 degree temp range, I would strongly suggest looking at the heater and see if the element is drawing power and actually heating... You'll hear the solenoid click, I know but it doesn't mean the heater is actually warming enough. Try cycling the heating element at least twice and see if it makes a difference... If not, go to an auto parts store, Walmart, whom ever and get a jug of fuel conditioner and double up on the amount it states to go into the tank... The conditioner helps destabilize the fuel so when it's injected the fuel can light off at lesser compression pressures.
I'd still bet it's the heating grid though... I've an 06... the heater didn't die but the solenoid controlling the heater did...
give it a shot... message me and let me know what happens and we'll go from there.
Bill
Old 02-24-2009, 01:35 PM
jcasey8379
Thumbs down
We tested the solenoid and it isn't even getting power. They are also wondering if the power for the solenoid come off the computer or the ignition, if that helps you any.....
Old 02-24-2009, 02:08 PM
Color: Khaki
Rep:12
To this, I don't know... I can see it happening either way but I'd be more inclined believing the temp swich somewhere around the front bumper could be your culprit ... they've caused problems in the past...
Old 02-24-2009, 02:21 PM
jcasey8379
Thanks for the tip. I'll check it out!
