Old 02-28-2009, 11:21 PM
fd1007 fd1007 is offline
Gender: Not Specified
fd1007 is on a distinguished road
Default Program an additional Key Fob?
I just picked up an 05 Quad 4X4 with a 5.7 Hemi.
My question is this.
I had an extra Fob from my 03 Quad. I was wondering how to program it (if possible) w/o a trip to a dealer.
It would be the third Fob for this truck. I like to keep a complete extra set (fob and key) as a spare.
Any help would be appreciated since the truck I recently purchased had no owners manual.
Old 03-01-2009, 02:44 PM
DaveDees's Avatar
DaveDees DaveDees is offline
Vehicle: 2010 Jeep Patriot
Trim Level: Latitude
Rep:40
DaveDees is on a distinguished road
Thought this might help you:
Programming Additional Transmitters
Up to four transmitters can be programmed. When programming a new transmitter, all transmitters intended for use with this vehicle, except the transmitter used to start the programming mode, must be programmed within the 30-second programming mode. To program a transmitter, turn the ignition switch to the ON position with the vehicle stopped. Press and hold the unlock button on a currentlt programmed transmitter for a minimum of four seconds and a maximum of ten seconds. While pressing the unlock buttor, press and release the panic button. Release the unlock button and a single chime will sound. This indicates that the module is in programming mode. Within thirty seconds, press and release the lock or unlock button on all transmitters intended for use with this vehicle except the transmitter used to start the programming mode. Successful programming will be indicated by a single chime.
NOTE: When programming mode is entered, programming is cleared from programmed transmitters and the transmitters will need to be reprogrammed.
All articles that coruscate with resplendence are not truly auriferous.
Old 03-01-2009, 06:14 PM
Thanks Dave, I will give that a try!
I appreciate the response.
Old 03-01-2009, 08:07 PM
Well, that did not work. I now have only one programmed fob and two de-programmed fobs.
Guess I am off to the dealer.
Old 03-03-2009, 08:56 PM
rpreburn rpreburn is offline
rpreburn is on a distinguished road
i work at a dealer it might not be the right remote even though they look the same but yeah most likely they will have to program it.
Old 03-04-2009, 06:09 AM
DaveDees's Avatar
Rep:40
Fd, sorry it didn't work for you. Like rpreburn said, it may not be the correct key, even though they look similar. Good luck to you!!
Old 03-04-2009, 09:48 PM
bigmike19956's Avatar
bigmike19956 bigmike19956 is offline
Vehicle: 2002 Dodge Ram 1500
bigmike19956 is on a distinguished road
I found the instructions for programming my 02 right in the owners manual. A dealer parts manager across the street from my work told me to look there. Give it a look see. Good luck.
Old 03-04-2009, 11:40 PM
Thanks guy's.....Ii don't have a manual, I bought the truck used and I haven't gotten an owners manual yet...
I tried the one poist but it wiped the computer of the second remote and the only one that would work after that was the remote I was using to go to the program mode.
I ended up at a dealer, spent $30 and got the other two reprogrammed so I now have my 3 fobs..
thanks anyway!
Old 09-29-2009, 11:46 PM
jjguarin jjguarin is offline
jjguarin is on a distinguished road
I baught a 02 ram 1500 about 6 months and just baught a FOB dodge remote its OEM cuz it was on a friends 02 ram he sold and gave me the extra one he had. and didnt get any alarm remote when i baught it does anybody know how to program the remote without first having a programed remote if not does anybody know how much i cost at the dealer to program
thanks in advance.
Old 09-29-2009, 11:52 PM
i read something online saying it can be done but in nervous about doing it cuz it tells me i have to
1) Turn ignition to OFF.
2) Locate the Data Link Connector, its a black 16 pin connecter that is under the driver's side dash, right where your right knee would be. You have to look up into the dash from below to see it.
3) Ground pin 1 of the Data Link Connector by taking a wire or paper clip and running it from pin 1 to pin 4. Pin 4 is ground so you can just short pin 1 to 4 and it will be grounded. Grounding pin 1 tells the system you are ready to reprogram it.
4) Close all of your doors.
5) Turn the key to ACC then back off. The power door locks will lock/unlock. This is the signal that the system is ready for reprogramming.
6) Push a button on your key fob, doesn't matter which button.
7) If you have 2 key fobs, then press a button on the 2nd fob within 1 minute of pressing a button on the 1st fob. Both must be programmed at the same time. If you only have 1 fob then press a button 2 more times to signal that you only have one.
8) The doors will lock/unlock to signal the codes were received.
9) Remove the jumper wire from the data connector."
any opinions i just dont wanna fry my electrical system by putting two wrong wires together???
