speedometer issues!? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 03-02-2009, 04:29 PM
RamJam
Cool speedometer issues!?
Hi All!!
My speedometer has a mind of it's own, occasionally it will work fine, but most of the time it is clocking twice the speed or pegged at 100 mph. Two weeks ago it started jumping around and the tranny was shifting up and down along with it, I replaced the Vehicle Speed Sensor (no cable...all electric) and it was fine for a week, last week it started pegging out at one hundred as soon as I turned on the ignition. Last night it started working fine again
It's about to drive me crazy! Anyone have similar issues?....any help would be appreciated.
Thanks, Norm
BTW, it's a '91 Ram B350, 360 ci, 4 speed automatic with electronic overdrive
Old 03-29-2009, 09:42 AM
tom9705ram
i had a similar problem in the past and replaced the instrument cluster. mine was only reading have the speed. was like 10 bucks at local salvage yard
Old 02-06-2011, 01:39 PM
Megacab07's Avatar
Megacab07 Megacab07 is offline
Vehicle: 2010 Ram 1500
Megacab07 is on a distinguished road
Have similar problem in my 90 w250. Was told by shop the insturment cluster is notoriuos for failing. Have one ordered. Will let you kow if it works
Old 02-23-2011, 07:25 PM
billrath14 billrath14 is offline
Vehicle: 1992 dodge ram150
Trim Level: le
Color: blue
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
billrath14 is on a distinguished road
I took my speedo out of the cluster and put it all back together and now it dont bounce around. The only thing I figure is it wasn't getting a good connection somewhere.
Old 05-03-2011, 11:29 AM
Almeida Almeida is offline
Vehicle: 2004 Dodge Ram
Color: gray
Almeida is on a distinguished road
I had the same problem before and the problem was corrosion on one of the plugs on the ABS module,i cleaned it properly and used moisture repellent spray and its been working fine for about a year,hope this will fix your problem
Old 05-03-2011, 12:44 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i had a simular problem the cause was a lead foot good luck finding a solution
Old 05-05-2011, 07:21 PM
unclesonny unclesonny is offline
unclesonny is on a distinguished road
Smile
Replaced Speed sensor on drivers side of transmission tail shaft section and it stopped the speedo going crazy.. I have a 90 B350 WITH 318 CONVERSION VAN. Part was under $50.00 and it cured the surging. PCM needs to know the speed the tranny is working at to adjust the speedo on dash..
Hope this helps..
