Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 03-03-2009, 10:35 PM
09sport's Avatar
09sport 09sport is offline
Vehicle: 2011 quad sport HEMI 4X4
Color: DWB
Rep:30
09sport is on a distinguished road
Talking self oil change for 09
I changed engine oil last Friday (right before got dents) oil change ding is still dinging.. is there any way can be reset??
2011 Quad Sport 4X4 DWSB HEMI
2010 Harley FLSTF Fatboy Black
2009 Harley FLTR Road Glide Black
Old 03-04-2009, 12:31 AM
Big Country
Double check the owners manual, but I think the procedure you have to follow is this. Get in the truck, insert the key into the ignition and turn it to "On" but don't start it. Within 10 seconds fully depress the gas pedal and release it 3 times. I believe it dings when it has been done successfully.
Old 03-04-2009, 02:30 AM
09sport's Avatar
Color: DWB
Rep:30
Talking yeah!!
thanks much I'll try!!
Old 03-04-2009, 04:54 PM
cue244's Avatar
cue244 cue244 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport 4x4 Crew
Color: Blue
Rep:57
cue244 will become famous soon enough
It is in the maintenance booklet on how to reset it. But it sounds right about the pedal thing.
Old 03-04-2009, 06:47 PM
09sport's Avatar
Color: DWB
Rep:30
done!! thanx!!
Old 05-10-2009, 05:45 PM
Cibalo Cibalo is offline
Cibalo is on a distinguished road
I just went out and tried this a bunch of different ways and it didn't reset it. Normally I would look in the owner's manual but there isn't one in the truck. Truck has a build date of 04-2008 and is a 4.7 L single cab long bed. When I turn it to the on position I get a bunch of dash lights and 5 chimes. Then there is about a 3 second pause and then a chime for the change oil.
I've tried doing it fast and slow, doing it while the chimes are going, doing it after the chime, doing it after the change oil message ends, etc. Any ideas on what else I should try?
Old 05-10-2009, 07:07 PM
DavidNM DavidNM is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Laramie Crew
Rep:13
DavidNM is on a distinguished road
I think that was the procedure for flooding the engine
Old 05-10-2009, 07:11 PM
Rep:13
The manual says to turn the key to the on position but don't start the car, depress the accell peddle slowly 3 times within 10 seconds, and then turn back to off position. It doesn't say anything about a 'ding' to confirm. Instead it says to restart the engine and if the alarm is still there you didn't do it rignt.
