Old 03-05-2009, 03:53 PM
Megacab07's Avatar
Megacab07 Megacab07 is offline
Vehicle: 2010 Ram 1500
Megacab07 is on a distinguished road
Default Sub for 08 Megacab 1500
Any ideas where I can pick up a subwoofer for my mega? I would prefer a factory model but might go with an aftermarket if a good fit. It would have to fit under the rear seats . The radio i have is the factory with 6 cd changer and nav. I like the sound now but think a sub would put it right at the top. I do not think there is a harness for the sub in the back. Year is 07 and it is an 1500 laramie if that is important
Old 03-05-2009, 04:04 PM
Check out JL audio or Alpine for subs and amps, Sub Zero for boxes. I've seen some other links to boxes built specific for your truck posted here in the Audio section. I need to find one that will fit under my back seat as well.
You will need an amp and some wire. You can get a signal off your rear speaker to patch in to the sub. One item that comes in handy is getting an amp that has a remote gain control. That way, you can tweak the gain from the front depending on your listening mood.
Sorry I can't be of more help...I'm a bit of an audio noob myself!!!
Old 03-05-2009, 05:25 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I assume you are not wanting to lose any space behind the seats. One 10" sub would probably suffice if under the seats is where you want it.
Old 03-17-2009, 11:53 PM
Lomaxx777's Avatar
Lomaxx777 Lomaxx777 is offline
Trim Level: Captin seats, Hemi
Color: BRILLIANT BLACK
Lomaxx777 is on a distinguished road
Where can i find plans to make a subwoofer box for my 09...all i can find is the Mopar box and its over 600 dollars ....?
"It's not our duty to die for our country, but to let the other S.O.B. Die for his."
