Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10
Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 03-05-2009, 06:36 PM
96-V10's Avatar
96-V10 96-V10 is offline
Vehicle: '96 V10 4X4 2500 QC
96-V10 is on a distinguished road
Question Question for a V10 mechanic
Hi all,
I was wondering if someone that has taken apart a V10 can tell me if the cam gear is all metal.
Anyone know?
Thanks
Toys: '96 Ram 2500 V10 4X4, 07 Nitro R/T, '66 Monaco 500 (old MoPar project)
'90 Yamaha FJ1200 (Economy vehicle)
Old 03-05-2009, 08:17 PM
cerres cerres is offline
Vehicle: 2006 4*4 3/4 Quad, 5.9 Auto
Trim Level: SLT Big Horn
Color: Khaki
Rep:12
cerres is on a distinguished road
If you're worrying about gear wear and chain stretch, put a socket on the bolt in the center of the crank and see how many degrees of freeboard you feel.. trust me, you'll know when you try to move the cam/valve train... if it's over 4 degrees, it's time for parts... Also, if the engine's top end seems stronger than before, it's because the cam is behind the crank thereby allowing the cylinders to fill for a longer period of time,
Old 03-06-2009, 05:56 PM
96-V10's Avatar
It only has 80K on it, I was wondering if I can expect to get past 125k without a cam drive swap.
If it has nylon on the cam gear, I won't trust it past that.
Old 03-06-2009, 06:19 PM
Color: Khaki
Rep:12
I honestly don't know however if it's the same chain assembly they use on the V-8's, she's under another 20% of continual load dragging two more cylinders worth of parts around... my guess it would be a good idea... but before you do it, see how many degrees of free crank movement you have... and go from there.
Old 07-25-2009, 03:57 PM
Airstar
Late response. Sorry.
The Dodge V10 has all steel gears and chain. It is not a roller chain. Cam gear has large lobe for cam position sensor. I have 110,000 on mine and it has wear and is limp but not loose. I run Mobil 1 and it is lightly bronze color in timing cover. I did have spalling on top of cam lobes and the cam bearings were trashed. One came out with cam. I am changing cam lifters bearings and timing set. Cloyes makes a timing set. Rockauto.com has them.
Old 07-26-2009, 03:06 PM
chody19 chody19 is offline
chody19 is on a distinguished road
do you guys now how long i can hope these v10s last for befor you have to work on them or reuild them
Old 07-26-2009, 03:08 PM
Should be able to get over 100,000 on it without a problem .
Old 07-26-2009, 10:13 PM
96-V10's Avatar
Thanks for the info. I believe that if the truck gets synthetic oil every 3000 miles and I keep up on all the maintenance it should go for a long time but if it had that stupid nylon covered timing gear like the '60s V8s, I would be opening it up to put an all metal one in it just for fun.
Glad to hear it is all metal!
Thanks again
Old 05-26-2010, 03:46 PM
sasquatch661 sasquatch661 is offline
Vehicle: 1999 Dodge Ram 2500 Quad Cab
sasquatch661 is on a distinguished road
Was wondering that myself. I've got 132k and still going strong. Running full synthetic changed every 4k. Guess I'll find out when the time comes.
