Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 03-21-2009, 05:23 AM
soulweaver
Default Oil problem
I only have one issue with my truck. When I rev the motor up my oil light comes on and the motor starts to bog down and looses power. I have no clue what it could be. If any of you have any idea I would appreciate it. Also, if you have an Idea please tell me how to check it.
Also, I have a 1992 dodge 150 4x4 318
Old 03-21-2009, 09:30 AM
cerres cerres is offline
Vehicle: 2006 4*4 3/4 Quad, 5.9 Auto
Trim Level: SLT Big Horn
Color: Khaki
Rep:12
cerres is on a distinguished road
how many miles do you have on your 318... the reason I ask is there's a phomonemon the overwhelming number of the masses aren't aware of.
Old 03-21-2009, 11:06 AM
soulweaver
about 15,000 on the rebuilt motor. and 160,000 is what shows on the odometer
Old 03-21-2009, 11:17 AM
Color: Khaki
Rep:12
Get into the engine... From the oil pump down to the sump, something isn't sealed. If she's bogging as you give her gas, this is most likely a friction issue. 15K isn't enough for me to comment on anything else but a true mechanical failure, assembly mishap, etc...
Old 03-21-2009, 11:20 AM
Sounds like the oil pump is cavitating (air) and may not be totally set in place or isn't sealing to the block.
Old 03-21-2009, 11:33 AM
soulweaver
I have had it checked out 4 times and they can't find nothing wrong with the oil pump/anything to do with oil.
Old 03-21-2009, 12:26 PM
Color: Khaki
Rep:12
Unless they've removed the pump, they're guessing. The only other thing to go wrong would be the oil pressure sender... they do fail but it's rare.. usually a failure relates to a leak....
Old 03-21-2009, 12:28 PM
soulweaver
Ok thanks, I will check it when the rain dies down.
