Old 03-26-2009, 11:04 AM
VA4MEDS's Avatar
VA4MEDS VA4MEDS is offline
Vehicle: 2010 5650 lb LeadSled
Trim Level: LeadSled
Color: Austin Tan Pearlcoat
Rep:48
VA4MEDS is on a distinguished road
Angry '06 Hemi New Exhaust & Codes HELP!!
First off, I'm a Old School mechanic 62 yrs young. Give me a carb motor no problems. Built & raced my own for many years. EFI I'm lost.
Installed Thorley Tri-Y mid headers, True Duals, cutouts, X-pipe, dual FM 50HD mufflers SI/SO, cats deleted, downstream 02 sensors hung, and 3" pipe off the headers to the back of the r/rear tire.
Here's the codes I get w/ superchips:
P0300- Multiple cyl Misfire
(forgot#) 1/1 sensor rich
(forgot#) 1/2 sensor lean
I have cleared the PCM w/SC
Cleared PCM by disconnecting pos batt post and grounding it on neg post. (Hard reset? Found tip on HTC)
Removed TB & PCV and cleaned them off the truck.
Checked upsteam 02 wires & connections. All OK.
Checked all injector & coil pack connections. Tight & Locked.
No exhaust leaks.
Truck will idle for 3 hours & not have a code.
Take it on the freeway, fine for about 8 miles, then gets multiple cyl misfire code and if you floor it, the trk has no throttle responce 'til the peddle is at the floor then it drops 2 gears @ 70, stumbles more for about 2 seconds, then wham!!, all 8 cyls start firing and take off like a rocket. Soon as I let off, starts misfiring again.
I am at a loss because I searched 4 forums, asked other gearheads, & no way that I've found to fix the misfire.
I'm about to pull the rest of my balding hair out because of this.
N2O/Nitro-Meth is like a Hot Chick with a STD.. You know what will happen if you hit it..But you just don't care anymore..
'10 5680 lb LeadSled CC - 13.401 @ 100.460 MPH...Custom Tunes by white lightning...Pushed & Chilled by Mr. Freeze
Old 03-26-2009, 09:10 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
Red face
With the Lean and rich codes you are showing there is definatly a Mis-Fire issue going on .......... All I can say is that you will need to take her to a dealership so that the technician can ride along with you while the truck is messing up. If this all started with the new exhaust- - - - -get rid of that exhaust!
Old 03-27-2009, 11:36 AM
Fast Willy's Avatar
Fast Willy Fast Willy is offline
Vehicle: 2008 Dodge Ram QC
Color: Blue
Rep:31
Fast Willy is on a distinguished road
Send a message via AIM to Fast Willy
Your going to have those codes because of the cats. I believe you can buy a predator and have the rear 02 sensors shut off and that should solve the problem I believe. You mike want to give diablo a call and ask them for sure though.
Old 03-28-2009, 07:40 AM
VA4MEDS's Avatar
Rep:48
Followed some suggestions and it's FIXED. Drove about 20 miles & no codes.
Installed bungs in L/ collector & for downstream 02s & non-foulers.
I unwrapped my #1 sensor wires out of the loom and over the tranny in order to reach the drivers side. Pain in the butt to do as they were entwined with the other 2 sensor wires. Long process but it worked.
Why would anyone take their trucks to the stealership when there are so many knowledgeable people hanging out at the different forums?
Thanks for the suggestions everyone!!
