Old 03-22-2015, 02:42 AM
watajob watajob is offline
Vehicle: 2012 QC
watajob is on a distinguished road
Default Knowledgeable/experienced answer needed...
OK
I've searched here 12 ways to Tuesday and Googled the snot out of the question: Can the lower Bosch Iridium plug be used for the upper Bosch Copper plug to extend service intervals with no damage/performance issues? Or, is their an Iridium plug of a different brand of correct size/configuration/heat range that might also do the trick? Id love to hear directly from folks that have done it and what their results were. Thanks.
Old 03-22-2015, 01:27 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
All I can tell you, my experience with Denso Iridium plugs in my hemi. It runs better with Champion Copper plugs. I have 99,000 miles on the Champions in my hemi Magnum wagon. My secret: gap them 10 thousands closer than spec. When I pulled the Iridiums at 100,000 miles, the end of the plugs were missing. Pulled a Champion at 90,000 and still looks good! I run 1 range colder plug than spec also, no issues with cold weather, I spray nitrous at the track.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 03-22-2015, 01:48 PM
Hornet Hornet is offline
Vehicle: 2014 RCSB 8sp/3.21 geared Ram
Trim Level: Sport lowered 4X4
Rep:488
Hornet is a glorious beacon of lightHornet is a glorious beacon of lightHornet is a glorious beacon of lightHornet is a glorious beacon of lightHornet is a glorious beacon of light
Just to add to Hydrex's post about closing the plug gap up,it actually adds a little bit more timing .
A tighter plug gap takes less spark energy to jump the gap,so the coil saturation period is shorter,which effectively adds timing to the engine.
As long as you have a big enough spark to ignite the air/fuel mixture it usually adds a bit to the power,nothing you'll be able to feel by butt dyno though,but enough it'll sometimes be noticable on an engine dyno.
It used to be a common trick back in the days of single coil ignition systems,not as common now with multi coil systems,as the gain isn't as noticable on the later multi-coil systems
Old 03-22-2015, 08:32 PM
Vehicle: 2012 QC
Good info. But, I'm still looking for a 4.7 owner that's been there and done that. Us old men don't like taking chances!
Old 03-22-2015, 08:51 PM
Rep:488
I think Snursak tried it,or was gonna try it,but don't quote me on that.
Hopefully Sean chimes in soon
I'm not close to plugs yet,so i haven't even gave the idea any thought .
I had mine all out and checked their gaps before the truck went on the dyno,but that's as far as i've gone on plugs
