Erratic Idle and dying problems on 97' 1500 5.9L - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-01-2009, 01:53 AM
chrismcr6 chrismcr6 is offline
Rep:12
chrismcr6 is on a distinguished road
Default Erratic Idle and dying problems on 97' 1500 5.9L
Hi all,
I have a 97' Dodge Ram 1500 4x4 with a 5.9L and about 104K.
Lately my idle when I come to a complete stop will LOOP or surge. It goes up and down, up and down until I start to go(within about 1k RPMS). It only does this when I stop at a light or w/e. It does not do this when I start the truck, and sometimes It Never does it. Its really erratic and non consistent. It has died on me a few times after the idle drops too low. Also, when/before I get to a stop, if I put the truck into nuetral and then roll to a stop, this problem rarely happens???
here is what I have tried/changed so far without any luck:
IACV-Idle air control valve.
New air filter,
check all vaccum lines, didnt find any aparent leaks. Tightned all loose connections.
What else should I check, it is really starting to bother me.
Thank you for all your help
Old 04-02-2009, 09:39 PM
Rep:12
anyone???????
Old 04-03-2009, 09:06 PM
fd1007 fd1007 is offline
Gender: Not Specified
fd1007 is on a distinguished road
We had a similar issue with our durango and it's 4.7 a while back.
I took it to a buddy who is a mechanic and he cleaned the heck out of the throttlebody and all of the parts attached.
Problem was solved.
Old 04-03-2009, 09:08 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2016 Ram 2500 4x4 LongHorn Meg
Trim Level: LongHorn
Rep:178
Burkdadhemi has a spectacular aura aboutBurkdadhemi has a spectacular aura about
Hows your Fuel pressure, just sound like a fuel issue.
2500 Megacab 4x4
Longhorn Brilliant Black Pearl 6.4L
Cattle Tan Interior
Old 04-04-2009, 11:58 PM
ph3nom3non03's Avatar
ph3nom3non03 ph3nom3non03 is offline
Vehicle: 2000 Dodge Ram 1500 4x4
Trim Level: SLT LARAMIE
Color: Intense Blue Pearl
ph3nom3non03 is on a distinguished road
im on this same subject in mechanical problems and solutions the post is in dier need of advice im trying to figure this out myself but when i do i will definitly be posting on this im going to be redoing my intake gasket and checking the pan that lays in the intake but read up on it and see where your standing
Old 09-16-2011, 01:14 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
TPS will cause that as well. Cheap fix.
I Am Groot !
Old 01-26-2012, 07:01 PM
indyjoker's Avatar
indyjoker indyjoker is offline
Vehicle: 2001 ram 1500 4x4
Color: grey
indyjoker is on a distinguished road
i had about the same problem check the crank position sensor,fixed mine right up
Old 01-26-2012, 10:10 PM
selfserve217 selfserve217 is offline
Vehicle: 1994 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Green
selfserve217 is on a distinguished road
I would agree with sonocavito.....check the tps. You should be able to use a multimeter to test the voltage to the sensor as well as what the sensor puts out itself. There are 3 stages you run the test in.....1 for signal voltage (at the connector), one for sensor voltage at closed throttle, and one for sensor voltage at WOT (key on engine off of course). Don't quite remember what the voltage ranges are at the moment, but I can get them to you if you need them. that is a simple way to check whether or not the TPS is on the fritz. I'm not certain about the Crank sensor, as the readings it takes is very imperative to the trucks functionality. It's one of those parts that if it goes bad, the truck simply will not run. Let me know how it turns out.
Old 01-26-2012, 10:32 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Got me on this one, all I can think of is this, the tps screwing up will generally cause the tranny to really like to run in overdrive, and not downshift when the motor is mashed. Good luck, and please come back to this site when you figure it out, and publicize!!!
