Old 04-01-2009, 08:07 PM
harofreak00's Avatar
harofreak00 harofreak00 is offline
Vehicle: 2002 Ram 1500 Sport Quad Cab
Rep:15
harofreak00 is on a distinguished road
Default drivers Quad Cab door doesn't open
My drivers rear Quad Cab door doesn't open. It appears the top latch is working, but the bottom one is sticking. The previous owner said her husband used to have the "trick" for opening it, but he has since passed away. Any ideas?
2002 Ram 1500 Sport Quad Cab Short Box | 5.9L | Black | 145k
Old 04-01-2009, 08:10 PM
Try pushing "In" on the door at the same time you pull the latch. If that works, I suspect the latch and bottom striker need a bit of adjustment.
Old 04-01-2009, 08:18 PM
Rep:15
I gave that a whirl and it still didn't budge. I also tried spraying some PB Blaster on the lock mechanism through the crack in the door, but that didn't help either.
If I take off that door panel will it give me access to the lock? Maybe one of the rod's broke or something?
Old 04-01-2009, 08:21 PM
Yes, you can gain access to the door opening mechanism through the inner panel. But I suspect the previous owner didn't do that every time he needed to open the door. I still suspect the latch / catch is binding.
Maybe it needs to be lifted up on while you pull the latch.
Man, this stuff drives me nuts...LOL...I'm sure you are goin' crazy too.
Old 04-01-2009, 08:32 PM
Rep:15
You're probably right, LOL
Believe me, I've tugged and pulled on it every possible way, even with another guy helping me. Its not moving.
How difficult is the panel removal with the door closed? At least then I could check to make sure its getting the rod movement.
Old 04-01-2009, 09:04 PM
Rep:15
Well after letting the PB Blaster soak for a while I went and tried it again. I gave it a good 10-15 hard tugs and it finally burst open.
Inspecting the latch, it looks ok. In fact, the passenger side looks worse (and it works perfect) I took a wire brush to it, and also sprayed some silicon lubricant on it. After I shut it, it was the same way. I had to give it a good 5-10 hard pulls. Even after opening the door 5 times, its the same way. I don't see whats causing it to bind up. Pretty frustrating, but at least I know it does open if I need it.
Old 05-11-2009, 05:15 PM
billycanuk billycanuk is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
billycanuk is on a distinguished road
Default Huh! Mine too!
Hey harofreak ... it must be sumthin' in the air cuz my 2001 drivers' rear door isn't opening either! Exact same symtoms ... top latch seems OK but bottom latch not releasing. Any chance of digging this guy up and grilling him for some help? Maybe a seance is in order.. Please lemme know if you come across an answer. Thx ... Billy
Old 05-11-2009, 09:30 PM
StevoSRT's Avatar
StevoSRT StevoSRT is offline
Vehicle: 2013 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
Color: White/Gold
Rep:40
StevoSRT is on a distinguished road
try pulling up or pushing down on it or pulling it forward or backwards....
couldnt hurt lol
Stevo @ DriveSRT:
http://www.drivesrt.com/news/2012/12/srt-owner-profile-steve-crisalli-white-plains-new-york.html
Old 05-11-2009, 10:11 PM
crg1987 crg1987 is offline
crg1987 is on a distinguished road
If all else fails...hit it with a hammer!! The latch not the door!
Old 05-11-2009, 11:09 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
I had a problem like this on an old truck of mine, I had to replace the latch because over time shutting my driver door just banged on the latch of the back door that it went bad. that might be why your passenger door works fine, it does not get used as much.
