drivers Quad Cab door doesn't open - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 05-11-2009, 10:29 PM
hmmm...looking at the catch, I suspect the door is out of alignment forwards and is binding on the catch. This might be a body shop job to re-align the door and they might suggest a latch replacement at the same time.
Old 05-12-2009, 08:43 AM
08quadram's Avatar
08quadram 08quadram is offline
Vehicle: 08 Ram Quad 1500
Color: silver
Rep:22
08quadram is on a distinguished road
I had an old '76 Dodge Royal Monaco when I was in high school (well it wasn't so old then). The rear door would not open when I bought it from the inside. I took off the door panels and just cleaned up the linkage and oiled it. It has spend many o years driving on gravel roads and the dust had gummed up the linkage and mechanisms enough that they wouldn't work. After a good cleaning and oiling they worked like new.
Did it see a lot of gravel?
Mike
'08 1500 Ram, Quad 4x4 Bighorn, Silver, 20" wheels, 5.7 Hemi/MDS, 3.92 axles
"Meddle not in the affairs of dragons, for thou art crunchy and good with catsup" -Doc, IFSJA
Old 06-12-2009, 07:01 AM
Kummipuru Kummipuru is offline
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Kummipuru is on a distinguished road
I have an opposite problem. The LH rear 1/2 door bottom latch does not close at all. Only the upper latch closes and holds both doors closed...
I tried to move the latch mechanism with my finger, and it seems it has a spring broken or sth, because there is no resistance in either way...
Can anyone recommend an online store to look for a new one? So far I have had no luck. The only latch offered is the hood latch. The same thing with ebay...
Old 01-05-2011, 09:09 PM
billycanuk billycanuk is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
billycanuk is on a distinguished road
I ended up soaking the bottom latches with tons of penetrating oil, leaving it overnight and then placed a block of wood against the inside of the door by the lower latch and was able to persuade it to open with a sledge hammer! Definitely need to replace the lower latches.
Old 01-06-2011, 09:28 PM
95ram 95ram is offline
Vehicle: 1998 dodge ram 1500
Color: red
95ram is on a distinguished road
I had the same problem with my 98 ram. pb blaster was only a temperary fix. I ended up just replacing the latch.
Old 01-10-2011, 11:23 PM
firecat firecat is offline
Vehicle: 2000 quad cab 4x4
Trim Level: sport
Color: red
firecat is on a distinguished road
I see im not the only one yours looks just like mine . are roads get salted and sanded around here .and it gets in all around that catch area im costantly wiping the shit outta their. im thinkin some new latches and invest in some mud flaps .
Old 01-16-2011, 07:42 PM
D.A.'s Avatar
D.A. D.A. is offline
Vehicle: 1998 Dodge Ram 1500
Color: Green & Black
D.A. is on a distinguished road
I just went through this today with my 98 quad cab. Drivers side lower latch not working. It was popped, but wouldnt open. Tore the interior door panel off and took the rod off the lower latch. The thinger that the rod goes to wouldnt move at all. After tugging on it and rip-snortin tryin to get it open, I just gave it the boot and it popped open. Latch is froze like a lake in winter. Now the latch needs replaced. Anyone who replaced their latches, where did you get them from and what was the cost on them?
