Old 04-02-2009, 10:48 PM
feztuz's Avatar
feztuz feztuz is offline
Vehicle: 2005 Dodge Ram 1500 5.7L Hemi
feztuz is on a distinguished road
Default Amp Installation - Need Ideas
OK everyone - I have an amp for my truck
So because things are tight, I was wanting to do a self install.
Any tips on cable routing from the Cab to the battery that doesn't involve power tools? I really don't want to Tap the fuse box - I would rather pull direct power from the battery and use the turn on lead from the key. Once I get power inside the Cab I am good to go.
Thanks!
Old 04-03-2009, 08:32 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
The harness that passes through near the steering column, in the past I have punctured it with a screwdriver and ran the power wire through there. It is rubber, so no worry about the wire grounding out against the firewall. Just be careful about where you put the hole, as there is other wires going through that grommet as well. Depending on where you mount your amp, there is other rubber plugs on the floor you could pass it through...
Old 04-04-2009, 05:27 AM
bwoodredkneck's Avatar
bwoodredkneck bwoodredkneck is offline
Vehicle: 2001 dodge ram 1500 4X4
Rep:24
bwoodredkneck is on a distinguished road
Send a message via MSN to bwoodredkneck
send it thru the fire wall just poke a hole thru the rubber cover and run it under the carpet
Old 04-04-2009, 03:20 PM
logannull's Avatar
logannull logannull is offline
Vehicle: 2000 Dodge Ram 1500
Trim Level: Base Model
Color: Patriot Blue w/ Blue Flake
Rep:13
logannull is on a distinguished road
thats what i did with mine. and it works just as good.
ballin on a budget !
Old 04-05-2009, 09:07 PM
feztuz's Avatar
Thanks Everyone - I ended up running through the boot by the firewall. Got it all the way to under the back seat. As usual, you guys are on it!
Thanks again!!
