Old 04-04-2009, 04:35 PM
sincebeen's Avatar
sincebeen sincebeen is offline
Vehicle: 2012 Ram 1500 CrewCab
Rep:72
sincebeen will become famous soon enough
Question Tuner for 2009 5.7L HEMI MDS VCT
Any 09's out there with tuners yet? I had an Edge on my last truck, and as much as I loved it, I always wished I had gone superchips.
Wondering what to get this time; mostly wondering which one will take optimal advantage of the Variable Cam Timing (VCT).
Old 04-05-2009, 05:29 PM
Just wait for DiabloSport to come out with the Predator for the '09's...you'll love it!
Old 04-07-2009, 06:06 PM
cue244's Avatar
cue244 cue244 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport 4x4 Crew
Color: Blue
Rep:57
cue244 will become famous soon enough
I am waiting for the Predator to come out!! It blew the Superchips out of the water on my 300c!
Old 04-08-2009, 01:22 AM
Roger that, cue!!!
Old 04-09-2009, 11:51 AM
sincebeen's Avatar
Rep:72
It just seems like they've done a great deal of work on the PCMs, i'd hate to screw anything up. Transmission adjustments and + timing would be the big thing for me.
Old 04-09-2009, 06:44 PM
If you are worried about damage to your computer, don't be. There are thousands and tens of thousands of Predators out there on GM, Ford and Dodge/Chrysler vehicles.
The Predator is very versatile and has a huge set of options for setting cooling fans to run at lower temps (good thing for a HEMI which tends to run hot) speedo calibration for larger wheel and tire options, fuel delivery at WOT, spark advance, and just a whole lot of other options within their standard tunes. And, like I am about to do, a DiabloSport authorized tuner can do even more with this tool and the tuning software in conjunction with a dyno.
The transmission adjustment is basically increasing line pressure which firms up shifts, reduces slippage between gear engagement and allows the transmission to run cooler. This is a good thing as slippage, and the resultant heat generated by slippage, kills transmissions.
Within the spark tables, spark/timing can be advanced or retarded as needed to optimize engine performance and efficiency across multiple RPM ranges.
If your truck is running lean, and most HEMI's do under the stock program, using the Predator fuel options can richen the mixture across multiple RPM ranges to avoid a lean burn/knock situation, also good for your engine's efficiency and performance.
So don't be apprehensive about this tool. It's the best bang for the buck mod you can do. Combine it with a cold air intake and catback exhaust and be ready to be amazed.
Oh, I get nothing for this endorsement. I just have a lot of practical experience with this tool and I've seen nothing better out there for the HEMI.
Old 04-10-2009, 09:16 AM
sincebeen's Avatar
Rep:72
Well said MADDOG... really.
Old 04-10-2009, 12:17 PM
Glad I could help, sincebeen. Holler if you have any other questions about your truck!
Old 04-15-2009, 11:35 PM
RamHemi55's Avatar
RamHemi55 RamHemi55 is offline
Vehicle: 2009 Dodge Ram Sport 1500 Hemi
Color: Mineral Gray
Rep:14
RamHemi55 is on a distinguished road
Hopefully they come out with a programmer that is untraceable in the computer system so that the warrenty is not affected!
