Factory Spec: 5.7-liter HEMIŪ V8 engine - 390 horsepower, 407 lb-ft of torque.
Old 04-04-2009, 09:05 PM
cptsopiens's Avatar
cptsopiens cptsopiens is offline
Vehicle: 2009 Dodge Ram 5.7Hemi 4x4 CC
Trim Level: Bighorn Package
Color: Light Graystone
Rep:14
cptsopiens is on a distinguished road
Default Axle ratio and acceleration question
I am about to buy a Ram 1500 Bighorn 5.7L Hemi crew cab 4x4 for my daily driving vehicle and to pull a 7,500 lb camper about 6-8 times per year. The 3.55 ratio can pull 7,450 and the 3.92 ratio can pull 8,500 lbs. I prefer to have some reserve and would like to get the 3.92 ratio. The sales rep said I would lose some of the "ride" that I enjoy and the ability to accelerate off the block. I love the Hemi's ability to go 0-60 and I don't want to lose that. I am trying to educate myself on axle ratios and will go for the higher one if someone tells me they have great "off the block" acceleration. The Dodge site states
"A "high" ratio, one with a high number of drive shaft turns like the 4.1:1 example above, is better for quick acceleration, climbing grades, carrying loads or pulling a trailer. However, it results in lower fuel economy and is noisier when running at high vehicle speeds."
Keep in mind I do NOT care about fuel economy. Some sites say the worse gas mileage is undetectable to the user. I want to be able to pull adequately . Is the increase in acceleration in the 3.92 only in the higher RPM ranges and gears? Does it decrease performance in the lower gears "off the block?"
thanks for any help you can provide this long time aspiring Dodge Ram owner!
2009 Dodge Ram 1500 5.7L Hemi, 4x4, Crew Cab, 3.92 Axle Ratio, Bighorn Package, Leer topper.
Old 04-04-2009, 09:14 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2016 Ram 2500 4x4 LongHorn Meg
Trim Level: LongHorn
Rep:127
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
The 3:92 will give your more acceleration not less. I have 3:92 in mine and pull a 9000lb + trailer with no issue. He's just tring to sell. make sure you have the trailer package, If it's the 3:55 it don't have the full package.
2500 Megacab 4x4
Longhorn Brilliant Black Pearl 6.4L
Cattle Tan Interior
Old 04-04-2009, 09:37 PM
cptsopiens's Avatar
Rep:14
Default happy with acceleration?
I gather you are happy then with your acceleration through all gears and RPMs?
Not sure what you mean by the full package? I took home a 3.55 axle and pulled the trailer without trouble. It had a class IV hitch and built in wiring, so it seems ready to go. I don't think there is any advantage for them to sell me a 3.55 v. 3.92. They don't have either in my color and have to try and get it in.
Old 04-05-2009, 03:22 PM
Rep:127
I guess I should have explained it better, With the Trailer package it will have a 136 amp alternator, 750 amp hr battery, the next size radiator. Most 3:55 equipped trucks don't have this set up and the trucks that have the 3:92 gears are set up with the trailer tow package. Not saying your isn't it's just rare.
2500 Megacab 4x4
Cattle Tan Interior
Old 04-05-2009, 04:22 PM
That's all BS...the 3.92 is simply a lower ratio which is a better torque multiplier than the 3.55. So you won't lose any "ride" but the engine will run at a higher RPM at highway speeds but not significantly higher. And for towing, the lower the ratio, the better the truck will handle moving the load from a dead stop.
Freakin' salesman...he has a 3.55 truck on the lot he wants to sell...that's why he LIED to you or made up that ridiculous story.
