Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 04-05-2009, 08:17 PM
ram06bighorn's Avatar
ram06bighorn ram06bighorn is offline
Vehicle: 06 RAM 1500
Trim Level: Big Horn SLT
Rep:37
ram06bighorn is on a distinguished road
Default Another Towing Question
Hi Guys and Gals, I have another Towing Question. The Wife and I are looking at getting a camper and I'm confused as to how much my 06 1500 will handle.
I went to the Dodge web site for towing and it just confused me even more. here's what I have and what the web site had that confused me.
My truck is a 06 Ram 1500 4X4 with the Bighorn Package. It has 3.92 Axle Ratio and the 4.7L
The Dodge Web site said with the 4.7L and the 3.92 Axle with the 5-speed trans. I can tow 7,100 lbs but it also said with the same setup I can tow 6,050 lbs
All the trailors we are looking at are around 6,500 lbs
The trailor paperwork has a easy towing guide and has the Ram 4.7L Towing Compacity at 6,050 to 7,300
Someone please HELP
Old 04-05-2009, 08:21 PM
You might be confusing 5th wheel and tow behind ratings. Read the paper again and see if the two different ratings aren't for two different types of trailers.
Old 04-06-2009, 05:56 PM
Rep:37
Well I went to my local dealership and they were alot of help Gave them the info on the truck and he looked on the computer and said the only thing he could find was for the 3.55 rearend so he asked another guy and he said " I think with the 3.92 rearend you can pull 7300 lbs." SO I asked him do you think or do you know ha-ha and he said "I'm pretty sure it's 7300 lbs" So I'm still looking for the answer guess I'll surf the net somemore
Old 04-06-2009, 06:00 PM
Rep:37
The paper says Model Engine Tow Capacity
(2WD/4WD-AWD)
Ram 1500 QC 4.7L 6,050/7300
Old 04-07-2009, 10:30 AM
Danstona Danstona is offline
Vehicle: 2005 Dodge Ram 1500 4x4 5.7L
Trim Level: Hemi Sport
Rep:35
Danstona is on a distinguished road
Well, for 1 you can tow more with a manual, and I'm not totally sure, but I think you can tow more with 4x4 as well? Someone correct me if I am wrong. One question for you though, why did you buy the 4.7L if you knew you were going to be doing a lot of towing, and of that amount of weight? I know it may have been an after thought, but just where I'm coming from... you might be up sh$t creek without a paddle. I'm sure you will be able to two a 6500lb trailer, it just might be harder on the 4.7L and struggle a bit more on grades. Buy a good brake controller and look at a Tekonsha
Old 04-07-2009, 10:56 AM
Stoopid dealers...don't even know why it has two ratings.
Good point, though. A different gear ratio would change the rating but I remember when I purchased a crew cab diesel that they were very specific on GVWR ratings across powertrain options, gearing and type of trailer.
There's gotta be someone at Dodge who can tell ya what rating applies to what truck option.
Old 04-07-2009, 04:49 PM
Rep:37
I got the truck because some guy leased it and turned it back in with only 20,000 miles on it so Instead of paying $33,000+ for the truck I only payed $19,000 couldn't pass it up. As far as being up sh$$ creek without a paddle I think 7300 lbs is pretty good for a 1/2 ton with a 4.7L with 3.92 rear end accourding to Dodge that is what the Ram is rated for said it would handle the trailer with no problems but thanks anyway. the trailer I'm looking at runs about 6,300 lbs
Old 04-07-2009, 04:52 PM
Rep:37
Talked with Dodge yesterday and they informed me that the 06 1500 4.7L 4X4 with 3,92 gears has a GVWR of 7300 lbs the trailer I'm looking at is 6300 lbs so I should be good
Old 04-07-2009, 06:46 PM
dodgegal06's Avatar
dodgegal06 dodgegal06 is offline
Vehicle: 2002 Ram 1500, '78 Lil Red Exp
Color: Green (1500) red (lil red)
Rep:13
dodgegal06 is on a distinguished road
actually, danstona, you tow less with a 4x4; the weight of the transaxle detracts from tow capacity. Best towers are diesel 4x2 manuals hands down
Dodge Gals DO Have More Fun!
Old 04-09-2009, 05:04 PM
Aggie 5.7's Avatar
Aggie 5.7 Aggie 5.7 is offline
Vehicle: 2008 Dodge Ram
Trim Level: Lone Star 5.7
Rep:12
Aggie 5.7 is on a distinguished road
You can tow a lot more than your manual says. I wouldn't suggest trying more than 6.5k lbs with that small of an engine though
