1992 Dodge Ram w/ Cummins diesel Tranny options? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 06-10-2009, 12:48 PM
Russ Bellinis Russ Bellinis is offline
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
Russ Bellinis is on a distinguished road
Default 1992 Dodge Ram w/ Cummins diesel Tranny options?
A friend of mine has a 1992 Dodge Ram with the Cummins diesel. The overdrive case has stripped out. He lives in Mexico, so I checked with my local Dodge dealer this morning and found out that the part is discontinued and no longer available. So far I've searched with keywords "Dodge diesel w/ automatic transmission," "1992 Dodge Ram w/ Cummins turbo diesel & automatic transmission." I have reworded the search a couple of other ways, but I'm sure you get the idea. I always get the dreaded "No matches found" response. I hate to ask a tech question without doing a search first, but either the search function is not working or no one on the forum has ever had a problem with an automatic transmission in a Dodge Ram diesel. My friend is looking for options. He has heard that the overdrive case is the weak link in the early automatic transmission behind the Cummins diesel. He has found ads for rebuilt stock transmissions for the truck. He is also considering upgrading to a newer trans from a later model Ram diesel if he can find one in a wrecking yard. Another option is to convert the truck over to a stick shift. Does anyone have any suggestions as to which would be the best choice?
Old 06-10-2009, 08:41 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
Go to Diesel Truck Rescource........Search in the 2nd Gen Engine and Tranny Forum......
Old 06-11-2009, 02:55 PM
Thanks boostjunkie1, I just registered there.
