Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 04-20-2009, 05:51 PM
stangguy1
Default Rear end fluid change
got an 06 and the dealership told me the rear end fluid should be changed every 25000 miles and they was going to charge 175.00. Well i dont want to pay that much and will tackle the job myself. I looked under the truck and did not see a fill plug. Any info or suggestions about the job in general would be helpful.. from start to finish...
thanks for your continued support,
shane
Old 04-22-2009, 06:32 PM
Aggie 5.7's Avatar
Aggie 5.7 Aggie 5.7 is offline
Vehicle: 2008 Dodge Ram
Trim Level: Lone Star 5.7
Rep:12
Aggie 5.7 is on a distinguished road
Rear end as in rear differential?
There should be a plug on one side of the casing that requires some kind of alan wrench.
Old 04-23-2009, 09:37 AM
57Hemi08's Avatar
57Hemi08 57Hemi08 is offline
Trim Level: SLT Big Horn
Rep:42
57Hemi08 is on a distinguished road
Mine has a rubber fill plug in the rearend cover. You can take the cover off and pop the plug out, then put the cover back on and fill up the rearend. Then just pop the plug back in.
Old 04-23-2009, 09:25 PM
MAVERICK85 MAVERICK85 is offline
Rep:15
MAVERICK85 is on a distinguished road
Hey try google. I ALWAYS try searching google, and I usually find what I am looking for.
Old 04-24-2009, 02:29 PM
Nitemare90's Avatar
Nitemare90 Nitemare90 is offline
Vehicle: 1996 Ram 1500
Trim Level: SLT CC Short Bed
Color: Black (is there any other color)
Nitemare90 is on a distinguished road
Send a message via AIM to Nitemare90
i had the rear fluid change at my local Pep Boys and the charge was about $60. Now I have no way of checking that it was actually done just trusting they did it (of course all labor for that job)
Old 04-26-2009, 10:54 AM
WHITEY
stangguy - before you pop your rear diff cover off make sure you have a gasket you can reuse instead of rtv sealing it. If you have rtv you'll have to scrape and clean it off before you put on new sealant.
hemi - Pleae tell me your wrong about there being a rubber fill plug on your diff!
Old 09-14-2009, 05:18 PM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
my 07 has a rubber plug....so does all the dodge vans we have at work.
Old 09-14-2009, 07:16 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Changing the diff lube is very easy. Drain out the old stuff, clean the magnet,replace the drain plug. Open the fill plug, add the correct amount of (limited slip additive) fill with Mopar synthetic gear lube, weight given in owner's manual and amount, when it starts to run out the fill plug, it's full. I installed the Mag Hitec cover on mine and would highly recommend it , esp if you tow. Oh, dispose of the old lube properly, and try not to get any on you, it stinks like hell.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 09-14-2009, 08:09 PM
Make sure you do the gear oil change when required . My truck was to be done every 15,000 . Didn't do it . The posi clutches broke and destroyed the rear . Why they use such horrible posis in these ????? Lookin to put a locker in it here soon . Oh , the rubber plug in the cover is your fill port .
Old 09-15-2009, 06:40 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
yeah, make sure you get the refill plug off before you drain it...sometimes in my shop on trucks that get the rear differential fluid exchange, the plug is very difficult to get off, and thats on a lift...So, if your doing it on the ground, I would make sure of that, before I drain it out...good luck...
