Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 09-16-2009, 01:39 AM
Rep:4105
I have the rubber plug on mine, also.
-Cajun
Old 09-16-2009, 09:45 PM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
This is scary to hear. Are 2003 Dodge 2500 rams at work plows never had the oil changed....trannys went....no rear ends. And its synthetic oil to boot.
Wow thats unreal.....
Originally Posted by Toms Blue Ram 1500 View Post
Make sure you do the gear oil change when required . My truck was to be done every 15,000 . Didn't do it . The posi clutches broke and destroyed the rear . Why they use such horrible posis in these ????? Lookin to put a locker in it here soon . Oh , the rubber plug in the cover is your fill port .
Old 10-26-2009, 02:07 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
So there's no actual drain plug? You really have to remove the rear differential cover to drian the fluid? Damn...
Old 10-26-2009, 07:21 PM
Color: grey
Rep:12
You could use a syphin gun tp suck the oil out of the diff....I would not do it this way...
But it can draw alot of the oil out but not all....
Old 10-27-2009, 02:15 AM
Incognito's Avatar
Rep:72
I guess I better pick up a torque wrench and get the torque specs for the bolts, as I'm planning on changing the rear end fluid sometime soon.
Old 10-27-2009, 05:14 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
i had a 05 durango that i had added fluid to,stuckmy pinky in the fill hole and got no fluid so i added some.next trip to the dealership they said it was overfilled,that it doesnt go up to the fill plug,but trucks may be different,just thought i would mention my experience.
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 10-29-2009, 05:03 AM
Lil Black 4x4 Hemi's Avatar
Lil Black 4x4 Hemi Lil Black 4x4 Hemi is offline
Vehicle: 2016 Power Wagon
Color: Blue Streak
Rep:85
Lil Black 4x4 Hemi will become famous soon enough
Send a message via AIM to Lil Black 4x4 Hemi Send a message via Yahoo to Lil Black 4x4 Hemi
Weird, my old 94 GMC never had the rear end fluid changed in 175K miles. It had a drain plug though and not the rubber stopper. I'm thinking when I do mine I'm going to put a "real" rear diff plate on it. I just don't like the stopper idea personally.
Is this a normal thing for Dodge to say to have done? The way I was raised was that as long as the fluid in the front and rear wasn't contaminated you were ok.
Luke
Partial De-Badge (doors and tailgate)
My SLT may be gone, but it's not forgotten!
Old 01-02-2010, 12:09 AM
HEMI5150's Avatar
HEMI5150 HEMI5150 is offline
Vehicle: 2010 Dodge Ram Quad 4X4
Trim Level: SPORT
Color: Black Pearl
Rep:35
HEMI5150 is on a distinguished road
Be sure to look at a DODGE service manuel specific to YOUR truck and year because dodge is famous for many different things with their front AND rear differentials over ALL years.
Also filling to the "Fill Plug" until it starts to drain out is NOT always the correct procedure...! (some require LESS oil...!)
Not all differentials are created equal when it comes to service`s and interval`s.
Do yourselves a favor, use fresh new factory lubes that they came with everytime.
An overfilled differential will blow past the oil seals... then the cryin starts
All these people using all the over priced guru oils, think about it...
if it were that good, the MoCo`s would have installed it in ther in the first place.
They`re NOT going to install inferior lubes just to have to replace your drivetrain later on under their dime.
Save your money, change oils,lubes,filters when the service manuel recommends and you cant go wrong.
I`m not a big fan of synthetics BUT i will use them where the manufacture tells me to.
I read in here how some of the guys run their oils 10,000+ miles...(you got to be kiddin me) then wonder why they have problems later on.
So i`ve been told.... and i use to use it
AmsOil = AmericanMilitarySurplus oil
Geez, one would think you could buy it cheaper being that we paid for the military to buy it from us to start with...lol. That sh*t is actually made for jet engines anyway.
I stopped using Amsoil when i found that my engine ran quieter with the factory oil back in it.
You guys with the MDS hemi`s, i`d stop using FULL synthetics in the engines if i were you...
its NOT recommended for the MDS engines.
Show me where its recommended by the MoCo, and i will stand corrected.
If you use synthetics, you better make sure you`re using the recommended oil filter for synthetic oil useage.
Anyhow, my 2cents dont meen much... but just i`d thought throw it out there anyway
You might be able to bullshit your way to the top, BUT, it wont keep you there
Never believe what you hear, and only half of what you see
