Old 04-26-2009, 07:04 PM
dclange dclange is offline
dclange is on a distinguished road
Default Dodge 1500 5.2 problems. Help, please?
Hi guy's! New to the site, looks like a great site. Need some help with my sons Dodge Ram 1500 5.2 2WD. Truck has been running rough, loses power when you step on it, etc. All for the past couple monthes. He's been working on it himself. He has put in new plugs, wires, cap, rotor. Went to Advaced auto to let them scan it. Came up random misfires on #1, 4, and 7.
Thats why he changed the cap and rotor. (Plugs and wires a month ago) A couple monthes ago he had a scan done and it said bad cat and O2 sensors.
So yesterday I started to help him and we changed the O2 sensors. Took it for a test drive. Seemed to idle fine, drove it , shifted good. If you would step on it, the rpms would go up, but the truck would bogg down, it wouldn't speed up. He drove it this morning and it is worse, back to missing out. Checked to see if the Cat was/are is stopped up. Pulled the front O2 secnor in front of the Cat to see if that would help. Didn't make any difference. Truck missing bad, even at an idle now. I'm from the old school 50's and 60's
cars and trucks. I don't know much about computers and such on new cars and trucks. I don't even know how to check the dwell or timing on this truck, even thou I have the meter and light. Do you guy's have any suggestions on what to try. My son doesn't have much money and I'm laid off, so maybe with your kind help we can possibly fix it ourselfs. Any and all help is appreciated. Thanks, Dave.
Last edited by dclange; 04-26-2009 at 07:10 PM. Reason: Post year. The truck is a 1997 year model.
Old 04-26-2009, 09:25 PM
DavidNM DavidNM is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Laramie Crew
Rep:13
DavidNM is on a distinguished road
I am a neophyte when it comes to this stuff -- but as I read your post I couldn't help but think there's an issue with fuel injection. Have you checked the filters, injection system, etc.?
Old 04-26-2009, 09:57 PM
^^^^ Fuel filter or fuel pressure regulator could be culprits here. Also, check the EGR valve. They get carboned up and can really affect engine performance.
Lastly, it could be the fuel pump itself. They do wear out.
Old 04-26-2009, 10:58 PM
I have not thought of fuel injection system. I've never dealt with that before. I do know we put a new fuel pump on last fall, the one in the tank.
EGR valve, have not checked. With the motor missing on one or more cyclinders, could it be the timing? Timing chain? Do you guys think we should go have another scan done? How can we check to see if the injection system is working right. I really don't think it's a shortage of fuel, more of a mis firing thing, loss of power thing. Thanks for all the help!
Old 04-27-2009, 11:22 AM
MattRam2002
I kinda had the same problem on my 97 dakota, where it was running rough, replaced the fuel pump (expensive little bugger, and had a full take of gas when it finally went out so that sucked to) and it ran great, however i dont think it was acting like it was miss firing, but as if it wasn't getting much gas was my problem.
Old 05-01-2009, 10:24 PM
Magnum488's Avatar
Magnum488 Magnum488 is offline
Vehicle: 05 1500 4X4 Daytona
Trim Level: Daytona
Color: GoMango
Rep:13
Magnum488 is on a distinguished road
A quick check of the fuel pressure would answer the fuel delivery question.
12 Charger R/T R&T, Dynomax, Trinity, 180 stat
05 Daytona QC GoMango 4X4 Long tubes, Y-pipe, Airaid, NX 100 shot, Superchips
03 Durango's 4.7's 4X4's SLT one white one green
95 Ram 1500 4X4 MP computer, shift kit, more..
Old 05-07-2009, 06:03 PM
crg1987 crg1987 is offline
crg1987 is on a distinguished road
Make sure the spark plug wires are in the right spots. I had two of mine swapped and couldn't figure it out for the longest time. Good luck.
Old 04-14-2010, 05:50 AM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
1. Fuel pressure test. (I've had to replace my fuel pump)
2. Swap a coil that you know is good as a test. (Put in a brand new made in China Accel coil and it was no good. Put stock coil back in, ran fine)
Old 04-18-2010, 12:57 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
did you figure the problem out?
