Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 05-03-2009, 02:27 PM
rockymtnmopar
Default Power steering fluid leak
Hi,
New member here. 2005 3500 cummins with only 27k miles. Started leaking power steering fluid and have not been able to locate source. Lost about a half qt. in last week and 200 miles. Hoses look OK but have blow back so not sure. No squeaks or squeals steering is OK, just found the leak on the garage floor.
Anyone with experience here? Hope pump is not a problem.
Thanks,
rockymtnmopar
Old 05-03-2009, 03:08 PM
Normally, it is either a weak hose or a fitting that has started to leak. Check for weepage near the fittings or evidence of weepage through the hose near the fitting end.
Also, did you just have the truck serviced before this started happening? If so, the PS reservoir may be too full. Check the level.
Old 05-03-2009, 10:55 PM
jessman02 jessman02 is offline
Vehicle: 2004 dodge ram quad cab 4x4
Trim Level: laramie
Rep:13
jessman02 is on a distinguished road
Hey,check the pressure hose at the fitting, have found several bad crimps and the metal end is spliting and letting fluid pass by the oring, no quick fix, hose has to be replaced, hope this helps, jessman
Old 05-04-2009, 01:14 AM
GT's Avatar
GT GT is offline
Dodge Ram Forum
Vehicle: 2002 Dodge Ram
Color: Blue/Silver
Rep:682
GT is a splendid one to beholdGT is a splendid one to beholdGT is a splendid one to beholdGT is a splendid one to beholdGT is a splendid one to beholdGT is a splendid one to behold
Well, if you want to find the source. Fill it up, and get a buddy to turn the wheel back and forth while you find the leak. If you are losing that much fluid, you should be able to spot the leak.
www.Billet-Customs.com
ForumZ Decals & TShirts - Vinyl graphics + other Misc. Goodness!
Old 05-04-2009, 12:22 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Some darn good suggestions here. Any luck on locating the source of the leak?
Old 05-04-2009, 07:57 PM
rockymtnmopar
Default Power Steering Fluid Leak Update
Originally Posted by rockymtnmopar View Post
Hi,
Thanks,
rockymtnmopar
Update-
Thanks for al the great suggestions unfortunately it will not be a simple clamp or hose tightening. I wiped everything down, started the truck, turned the wheels and located the source. The pump has an aluminum cover about 5"X5" that faces up and is fastened with 4 good sized bolts. In the center is a castle nut and it is leaking at that nut. Not sure if it has an O ring or is loose, could not get a wrench on it from top or bottom. It sits 3.5 inches behind the fan shroud and a little higher. The cover has a number on it-F7AO-3583-AA. Any suggestions on what to do with this?
Thanks,
rockymtnmopar
