Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 05-08-2009, 02:14 AM
MrWonderful MrWonderful is offline
MrWonderful is on a distinguished road
Default truck trouble
i have an 04 ram quad cab 4x4 and am experiencing a noise that i just cant find and when i took it to my mechanic it didnt do it i thought it was my front diff or drive shaft but we removed the drive shaft and it still made the noise it sounds like a bad grinding noise but it goes away for a couple days then returns only for a few moments and of course wont do it with a mechanic in the truck has anyone else had a similar problem and any ideas what to check any help would be greatly appreciated
Old 05-08-2009, 06:32 PM
RamHemi55's Avatar
RamHemi55 RamHemi55 is offline
Vehicle: 2009 Dodge Ram Sport 1500 Hemi
Color: Mineral Gray
Rep:14
RamHemi55 is on a distinguished road
first place to check is the brakes, if its going away and returning then that might be it. also check the dust shield for the calipers. i had problems with that on my 01 ram. it would scrape once in a while. Could be just a hard spot in the rotors. Hope that helps!
Old 05-08-2009, 07:47 PM
thanks for the suggestion i did check the brakes but it isnt them it is a much louder sound than brake noise it sounds more like a differential carrier possibly grinding against the housing but i sure hope not. it could also be the transfer case.
Old 05-08-2009, 09:02 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
Have you pulled the diff cover to see if there is any exssive metal in it. Is this a 4X4 ?
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 05-09-2009, 12:50 PM
the mechanic at the shop said until he heard the sound he didn want to just guess at what it was since we arent sure wheather its the diff or the transfer case or the tranny or the suspension or even if its the cv joints in the front axles i think i just might try another shop today and see what they think nothing wrong with getting a second opinion it just doesnt seem to want to make any noise when the mechanic takes it for a test drive go figure huh
Old 05-10-2009, 11:02 PM
desperado08 desperado08 is offline
Vehicle: 2001 Dodge Ram
Rep:14
desperado08 is on a distinguished road
Send a message via AIM to desperado08
Is the sound something that's coming from under the hood?
Old 05-10-2009, 11:09 PM
the sound sounds like its coming from under the truck possibly the transfer case or diff or what not
i called the dealership and it appears i have a couple months and kilometers left on my warranty so im taking it in tommorrow and hopefully they can find and fix it i will post the answer to the problem when i know heres hoping it does it for them the sound of grinding metal just makes my skin crawl
just weird since i drove all over the place today and it didn make a single sound
