Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Recalls and TSB's.
Old 05-19-2009, 03:09 PM
Matt35F Matt35F is offline
Vehicle: 2010 Dodge Ram 1500 CC 4x4
Trim Level: SLT Bighorn
Color: Inferno Red
Matt35F is on a distinguished road
Originally Posted by RamHemi55 View Post
The light only comes on at a speed no more than 50 i think (which is kinda dumb cause it would be more useful on the highway).
I've had my MDS come on at highway speeds.
Old 05-19-2009, 09:20 PM
rockford ram rockford ram is offline
Vehicle: 2011 Dodge Ram 2500 Crew 4x4
Trim Level: laramie
rockford ram is on a distinguished road
Good info on the 2009 recalls. I have only had mine for a week and havent experienced any problems. I am calling my dealer asap.
Old 05-20-2009, 04:19 PM
sincebeen's Avatar
sincebeen sincebeen is offline
Vehicle: 2012 Ram 1500 CrewCab
Rep:72
sincebeen will become famous soon enough
The only reason i know what the light looks like is because my uncle has a black Ram just like mine and I took it out for a cruise; the "Fuel Saver" light was poppin on and off and on like you wouldn't believe. He averages 18.5mpg while mine is registering 13.5. I took it into the dealer last week (second time) and said "look, this thing has got to be BROKE".
They said everything is good according to the codes (pshhh).
However, the other half of the reason I was at the dealer is because I had a whistle coming from the rear end at 60+ mph. I figured they would replace the gears; they're replacing the entire axle! The tech did note that the MDS problem may be related.
They fixed two recalls while I was there the first time: 1st was something with the seat squeek and I've seen that mentioned here. The 2nd was a hose clamp somewhere. I'll post the recall numbers when I follow up...
Old 05-20-2009, 04:50 PM
mopartoya mopartoya is offline
mopartoya is on a distinguished road
Wink
My dealer called last week. There is a flash available for spark advance, and ruff idle. Nothing said about MDS. Goes in Friday for the PCM flash, and 1st. Oil Change. I'll let you know the outcome. Also, the MDS indicator can be disabled in the setup. Make sure it is enabled first. Also, it is noticable in the exhaust noise when in MDS. Mine will only every now and then show. A friend's '09 will stay on at 70 mph, as long as the road is level. I've wondered about tire pressure, brake drag, axle friction, etc. but, I believe it is something more with the computer. Seems those who have it working, it is on most of the time, and mileage averages around 19 mpg. Mine, hardly ever on, never about 50 mph, and about 13.5-14 mpg average. Also, for some reason, mine doesn't seem to have the peformance. Seems doggish. At WFO from dead stop seems okay, but passing at 55 mph, something is wrong.
Old 05-27-2009, 02:56 PM
jimf5 jimf5 is offline
Vehicle: 2009 Ram 1500 Crew Cab
Color: Detonator Yellow
jimf5 is on a distinguished road
Hi All:
I guess this thread is kind of sputtering out. If the moderator thinks I need to start a new one about MDS only please let me know.
I just took a short ride around Death Valley, about 110 miles, at crusing speed,65-68 MPH, and am getting 17.6 MPG.
The truck has 1700 miles on it with the 5.7 Hemi. Is this good,bad or not enough miles to get a good read yet?
I forgot to mention I live in Nevada about 30 miles from the outside of Death Valley and the temp. this time of year is only in the mid 90's
jimf5
Old 06-04-2009, 05:47 PM
cue244's Avatar
cue244 cue244 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport 4x4 Crew
Color: Blue
Rep:57
cue244 will become famous soon enough
I took mine in for the MDS light and they said my build date was to early for it. Also I can not tell when my MDS kicks in. I have an aftermarket exhaust but they claim it is working fine. Might go to a different dealer with the above info.
Old 06-05-2009, 08:18 PM
DaveFabry DaveFabry is offline
Rep:12
DaveFabry is on a distinguished road
Glad I saw this posting. I bought my '09 in late January and have been trying to find out about a "fuel saver" indicator ever since. The manual does not mention squat about it. I have EVIC and have not been able to see any reference about it nor do I see ever see any indicator going off and on. I have noticed a rough idle at times and I was expecting better mileage than I am getting. I had an '03 that got as good of mileage as this new one does. I am going to check with my dealer about the recalls that have been mentioned and will post what I find out. Thansk!!
Old 06-06-2009, 01:22 PM
RAMitDOWN's Avatar
RAMitDOWN RAMitDOWN is offline
Vehicle: 09 Dodge Ram
Trim Level: ST 4X4
Rep:24
RAMitDOWN is on a distinguished road
Thought I would point out that if your Ram doesn't have any steering wheel controls (buttons) on it then your Ram will also not have the MDS light.
At least thats what I was told by the dealer.
Old 06-09-2009, 10:26 PM
MikeD MikeD is offline
Vehicle: 2009 Ram 1500 Quad Cab
Color: Stone White
Rep:13
MikeD is on a distinguished road
The documentation of the fuel saver light for my '09 (build date in March 09) was in a separate supplement to the manual.
Old 06-14-2009, 04:21 PM
MisterOX2009's Avatar
MisterOX2009 MisterOX2009 is offline
Vehicle: 09 Ram Crew Cab
Color: Inferno Red
Rep:47
MisterOX2009 is on a distinguished road
Send a message via AIM to MisterOX2009 Send a message via Yahoo to MisterOX2009 Send a message via Skype™ to MisterOX2009
Got mine scheduled to go in on Wednesday.
