Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 05-09-2009, 04:06 PM
GunDog1 GunDog1 is offline
Vehicle: 04 Dodge Ram 1500 5.7L H
Trim Level: no clue
Rep:13
GunDog1 is on a distinguished road
Default Oil
What oil should I use in southern california for the 5.7 Hemi?
Old 05-09-2009, 04:12 PM
Danstona Danstona is offline
Vehicle: 2005 Dodge Ram 1500 4x4 5.7L
Trim Level: Hemi Sport
Rep:35
Danstona is on a distinguished road
What your manual says, 5w-20
Old 05-09-2009, 05:26 PM
black beauty's Avatar
black beauty black beauty is offline
Vehicle: 2000 Dodge Ram
Rep:23
black beauty is on a distinguished road
ya know when you get people talking about oil its going to be a fight every time its not bad to use thin oil i use 0-30 in my truck in the coldest time of the year and the hottest part of the year. its not bad to be changeing the different viscosity's but its more if you change the brand that is way worse for the engine. if you want to save yourself the fighting stick with what your truck calls for
Old 05-09-2009, 08:11 PM
DavidNM DavidNM is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Laramie Crew
Rep:13
DavidNM is on a distinguished road
OK - one comment, one question:
Comment: Lived in Phoenix for 30 years. I was always told (at leas for the cars I owned) to us a slightly thicker oil during the summer months (10w40) and in the winter months use (10w30).
Question: This is the first big truck I've owned and I'm out of the heat. What's the case for / against using a synthetic oil - or perhaps a blend? Is it that big if a deal to do so? My first oil change is in July - and if it makes that big of a difference I might as well start running synthetic.
Old 05-09-2009, 08:31 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
I would run the 5-20 Royal purple, I pull a 30' travel trailer in the southern heat with no issue at all. I grow up in Southern Cali in the high dessert and move to Alabama and it gets every bit as hot here as it does in the high dessert of cali. It's about lubrication and how well the oil stays on your bearings and maintains the clearances between the bearing and crank,cam. Also a full synthetic group IV will take the heat better and disperse it.
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 05-09-2009, 09:30 PM
I like synthetics. I ran a Chev with synthetic 10W-40 all year round with no problems here in Oregon. At 140K, when I pulled the engine to do a bore and stroke, it was in fine shape.
Some people run synthetics in an engine after it has had quite a few miles (+50K or so) on regular oil and experienced leaks at the seal areas. But since your truck is new, this would be a good time to switch.
Synthetics will increase the service interval for an oil change, as they don't break down as quick, and they are a superior lube being blended with more friction reducing components than you can get with standard oil.
Old 05-14-2009, 05:59 AM
Shorty
Default Oil
Maddog, do you actually know someone who experienced leaks after he started using synthetics in a high mileage truck, or did you just hear of people having leaks?
Old 05-14-2009, 09:37 AM
08quadram's Avatar
08quadram 08quadram is offline
Vehicle: 08 Ram Quad 1500
Color: silver
Rep:22
08quadram is on a distinguished road
Do you guys even have a cold time of the year? I can't imagine it enough to switch oil viscosity. wait until you get 30 and 40 below
I used to run 10w40 in the winter and 20w50 in the summer on my old Grand Wagoneer, but that was a tired engine. It was the easiest way to keep the oil pressure up.
I would follow the recommendations in the manual. 5w20. I'm running Mobil 1 full synthetic in my ram now. I haven't typically run synthetic, in the past, but will be giving it a try on this truck.
Mike
'08 1500 Ram, Quad 4x4 Bighorn, Silver, 20" wheels, 5.7 Hemi/MDS, 3.92 axles
"Meddle not in the affairs of dragons, for thou art crunchy and good with catsup" -Doc, IFSJA
Old 05-14-2009, 08:38 PM
RAMitDOWN's Avatar
RAMitDOWN RAMitDOWN is offline
Vehicle: 09 Dodge Ram
Trim Level: ST 4X4
Rep:24
RAMitDOWN is on a distinguished road
If your truck is still under warranty wouldn't increasing the interval be a problem ?
Old 05-15-2009, 07:01 PM
Zonestar's Avatar
Zonestar Zonestar is offline
Rep:235
Zonestar has a spectacular aura aboutZonestar has a spectacular aura aboutZonestar has a spectacular aura about
If your 1500 is a 2004 as listed in your vehicle information; the manual recommends 10W30 I believe. MDS did not show up on the HEMI till 2005.
