Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 05-09-2009, 03:27 PM
szarin
Default air conditioning suggestions
hey guys,
I'm in the middle... err starting to pull out my enging in my '99 dodge ram 1500. (long story). I want to rebuild it and maybe put some performance mods back into the engine. However because the truck is sitting on 35" tires, 4" suspension lift, i need to take out the rad/air condensor unit and the top cross member (aka rad support). I have a 2 ton engine hoist but even thats not tall enough to get the engine out. ... go big or go home does have some disadvantages heh...
My question is... how do i discharge the ac lines, taking the truck to dealership is not an option. If the truck were to start, it would just do extra damage to the block. Any suggestions or comments.
If i have to get/rent tools thats fine. I know the hanes manual says to take it to the dealership, but thats not an option.
I've got rad disconnected from the truck, the oil cooler lines removed. I dont think i can leave it lying off to the side because 1) where ever i would put/rest the rad it would get in the way of taking out the engine or it would get in the way of the 2 ton engine hosit.
thanks.
Old 05-09-2009, 07:39 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
Well, I know this is not right but I just open the line and let it out. 99 has R-134 so it's not as bad as R-12
MagnaFlow
Airaid Jr Kit
Royal Purple
Old 05-09-2009, 08:55 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
When you are letting it out try not to breath it in, do it in well vented area and be careful.
Old 05-09-2009, 11:05 PM
szarin
after finally getting a hold of my my mechanic friend he said the same thing... the biggest thing i was worried about was what the hanes manual said was a "special tool" to remove the connection on the tube that goes to the bottom of the condenser. When he told me it was just a regular fuel/oil cooler line removal tool i depressurized the system.
I was worried i needed a special crimper or something to get it off and back on.
Got the rad, a/c condenser, rad support outta the way. the engine is disconnected, tomorrow gonna pick up a throttle body plate to hook up the enghine hoist and then remove the engine.
thanks for the responses guys!
