Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Fuel System
Fuel System All Fuel Discussions. MPG - Mileage - Fuel System Maintenance including Air Filter Replacement.
Old 05-17-2009, 09:51 AM
DavidNM DavidNM is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Laramie Crew
Rep:13
DavidNM is on a distinguished road
Default Question about fuel?
So I've had my truck for about 3 weeks - have 2200 miles on it. (Laramie w/ 5.7 hemi)
When I bought the truck I asked the salesperson what fuel should be used - she said use the standard regular unleaded (I believe it's 87 octane). The manual says that the 5.7 is designed to operate in the 87 to 89 range of fuels but the manufacturer 'recommends' using 89, and, says you should not use premium.
So the obvious question - what fuel to use? Should I use the mid-grade which is around 88 to 89, or the regular. Since I live at a higher altitude (6500ft) does that make a difference.
Thoughts?
Old 05-17-2009, 10:05 AM
Zonestar's Avatar
Zonestar Zonestar is offline
Rep:235
Zonestar has a spectacular aura aboutZonestar has a spectacular aura aboutZonestar has a spectacular aura about
The owner's manual recommends 89 for optimum performance but it will run on 87. I would choose the 89. I pasted below the text from the owner's manual.
5.7L Engine
The 5.7L engine is designed to meet all
emissions regulations and provide satisfactory
fuel economy and performance when
using high quality unleaded gasoline having
an octane range of 87 to 89. The manufacturer
recommends the use of 89 octane
for optimum performance.
The use of premium gasoline
is not recommended, as it will not provide any benefit
over regular gasoline in these engines.
Light spark knock at low engine speeds is not harmful to
your engine. However, continued heavy spark knock at
high speeds can cause damage and immediate service is
required. Poor quality gasoline can cause problems such
as hard starting, stalling, and hesitations. If you experience
these symptoms, try another brand of gasoline
before considering service for the vehicle.
Old 05-17-2009, 03:01 PM
I agree...89 will be a much better fuel for your truck. And since it's not that much more expensive, prolly a better choice to keep that engine from running too lean at altitude.
Old 05-17-2009, 03:36 PM
crod crod is offline
crod is on a distinguished road
i run 89 in our 08 grand cherokee overland. (5.7hemi 345hp/375tq) the manual reads just like the text printed here.
Old 05-19-2009, 01:03 PM
jem_12usaf's Avatar
jem_12usaf jem_12usaf is offline
Vehicle: 2010 1500 Crew Cab Big Horn
Color: Blue
jem_12usaf is on a distinguished road
Stick to the 89. It might cost a few cents more but will be worth it in the long run.
Old 05-19-2009, 06:29 PM
erik108's Avatar
erik108 erik108 is offline
Vehicle: 2010 slt quad cab
Color: mineral gray
Rep:18
erik108 is on a distinguished road
89 octane only ! no 87 no 92/93 !!!!!!!!! the 5.7 HEMI is made to run on 89 !!!!
Old 05-27-2009, 05:37 PM
sincebeen's Avatar
sincebeen sincebeen is offline
Vehicle: 2012 Ram 1500 CrewCab
Rep:72
sincebeen will become famous soon enough
erik108, do you have anything to backup the "no 93" comment?
Cheers
Old 05-27-2009, 07:19 PM
Rep:13
The problem in new mexico is that I can't find a pump with 89. There's 86, 88 or 90. I've been using the 88.
Old 05-27-2009, 11:51 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
I use 89, but If I find myself in Mexico I will use the 88 also.
Old 05-28-2009, 12:22 AM
GunDog1 GunDog1 is offline
Vehicle: 04 Dodge Ram 1500 5.7L H
Trim Level: no clue
Rep:13
GunDog1 is on a distinguished road
Don't mean to crap a thread but am I making a mistake by using 91 in my 04 1500 5.7 hemi magnum?
