Old 05-18-2009, 12:51 AM
GunDog1 GunDog1 is offline
Vehicle: 04 Dodge Ram 1500 5.7L H
Trim Level: no clue
Rep:13
GunDog1 is on a distinguished road
Default Help!!
I went and got oil changed at valvoline and they pulled the trans dipstick and there was something on it. first thought was metal shavings so I brought it up to the dealer and they checked it. I had 100 miles before warrenty goes away. They checked it and said it is dirt. That it needs to be flushed and both filters changed. It has a grey look to it. I now have no warrenty and Im getting it flushed. What can I do if it is metal shavings???
Old 05-18-2009, 11:53 AM
black beauty's Avatar
black beauty black beauty is offline
Vehicle: 2000 Dodge Ram
Rep:23
black beauty is on a distinguished road
how many miles does the truck have? the warranty just expired right so im thinkin 100k but anyway have you ever changed the tranny fluid before, i don't know if the maintance schedule is the same on mine its every 30k.
now about the metal shavings the fluid most likely got bad enough it just wasn't taking good care of the lubricating.
in my experience their metal shavings (whats the truck made of, metal) it happens and will go away i would just give it a good flush and give it a little bit of time and then just change it
Old 05-18-2009, 03:32 PM
Trim Level: no clue
Rep:13
Its got 60,000 miles and when I bought it, it came with the 2,000 mile warrenty. I bought the truck at 57,000
Old 05-18-2009, 03:46 PM
Rep:4072
Is the transmission giving you any problems? As far as the flush goes, guess I am just a bit old school, but I believe in just draining the fluid, changing the filter, but not flushing it. Whatever trash may be in there is just going to be loosened up with a flush allowing it to wind up somewhere it shouldn't be.
Old 05-18-2009, 10:20 PM
Rep:23
after a little research the metal shavings is pretty normal mostly after the truck was brand new all the metal shavings come from the break in point of the truck. if its never been changed that would explain the discolloration in the fluid. really theirs nothing to be to worried about its pretty normal. nothing a good flush can't handle. after the flush check it frequently
Old 05-26-2009, 10:09 PM
Trim Level: no clue
Rep:13
THanks all I went ahead and got it flushed. I am about ready to take the truck for a rough drive Its been flushed for a few days now. I am going to get er warm and take out the dip stick and smell the fluid to see if it smells like burning. I was told to do this by someone. If it does smell like its burning And there is alot of fricton somewhere What can I do to go back on the dealership? It is recorded at the dealer that I came in with the problem before warrenty ran out, so If there is really a problem that could be bad later on in life What is the best way in coming at the to fix it for free?
Old 05-27-2009, 01:05 AM
Is it metal powder or metal chunks? Chunks = Not Good.
Metal Powder = Normal. It's wear band material from the bands...
Old 05-27-2009, 03:02 AM
Trim Level: no clue
Rep:13
They told me it was just really dirty fluid. The guy took his finger and scoped up a nasty blop off the bottom. Wasn't really chunks. Just some specks up metal (not much) and some goop.
Old 05-27-2009, 10:02 AM
Danstona Danstona is offline
Vehicle: 2005 Dodge Ram 1500 4x4 5.7L
Trim Level: Hemi Sport
Rep:35
Danstona is on a distinguished road
Sounds pretty normal to me.Transmission fluid will get discoloured from red to a brownish grey... best thing to do is flush it and then change filters and fluid. I had my trans fluid flushed and both filters changed. Just make sure they follow the guidelines of replacing the spin on inside the transmission. This filter if it is not installed properly can cause a problem with the truck not engaging reverse or drive from a cold start... it does go, but is slow to do so... Its something to do with the filter leaking out the fluid from the torque converter. Hope this helps....
Old 05-27-2009, 12:19 PM
Trim Level: no clue
Rep:13
It seems to be fine so far. The dealership did the service. So hopefully they no wat they are doing lol
