Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 05-20-2009, 06:09 PM
DaSOB's Avatar
DaSOB DaSOB is offline
Vehicle: 1998 Dodge Ram Ext Cab
Trim Level: SLT Laramie
Color: Light Driftwood Satin Glow
Rep:51
DaSOB will become famous soon enough
Question Dang pinion bearing went out AGAIN!
Howdy, y'all -
This is my first time on this forum - pleased to be here. Just in case anyone is wondering about my handle, my initials are SOB. For real! So I said to myself, why not be DaSOB?
I don't want to sound like I'm starting off with a rant, but I got an annoying problem I need to air out.
I have a 98 Ram 1500 2WD 318. I love the truck - it's been great, very reliable. It's a Babe Magnet, too... Anyway, my pinion bearing has gone out for the second time in 10 years. I had it replaced in June, 2006 and just had it replaced again today (5/20/09). $725 the first time and $550 this time.
I'm told that this is a common problem with the particular rear end that is used in the Ram. If that's the case, I'm probably looking at another expensive replacement in a few more years.
Question I have is, can I replace the bearing myself? If so, does anyone have a link to information on the procedure? Sure would save me a chunk of change next time!
TIA!
Ah Luv Muh Truck!!
http://www.ramforumz.com/signaturepics/sigpic2117_1.gif
Old 05-20-2009, 11:50 PM
08quadram's Avatar
08quadram 08quadram is offline
Vehicle: 08 Ram Quad 1500
Color: silver
Rep:22
08quadram is on a distinguished road
I would look at buying a service manual. I don't think it is very hard, just need the right tools. If it is a problem, you could always find a different rear end with the same gearing and swap it out. That might be a better solution if it is a common problem.
Mike
'08 1500 Ram, Quad 4x4 Bighorn, Silver, 20" wheels, 5.7 Hemi/MDS, 3.92 axles
"Meddle not in the affairs of dragons, for thou art crunchy and good with catsup" -Doc, IFSJA
Old 05-21-2009, 12:23 AM
red041500 red041500 is offline
Vehicle: 2009 ram 1500 crew cab
Color: bright silver
Rep:22
red041500 is on a distinguished road
replacing a pinion bearing requires alot of special tools and alot of patience. in order to make sure the rear end doesnt make any howling or growling you must set the pinion depth correct , and check tooth contact on the ring and pinion , and also backlash needs to be right. its not impossible to do yourself but its not like slappin a axle bearing in , alot more involved. then there is also the chance maybe bearing preload wasnt correct the first time you had it done leading to premature bearing failure (second leading cause only behind low fluid level).
Old 05-21-2009, 03:53 AM
Rebhays27's Avatar
Rebhays27 Rebhays27 is offline
Vehicle: 2001 Ram
Trim Level: Magnum
Rebhays27 is on a distinguished road
Hey SOB sorry I couldn't resist in my profession I hear that all the time and my initials arent even close to that I copied this from a different forum site I thought I had instructions on changing that bearing. I have included a link for a special tool that you might need (I do not personally know) If I can find those instructions I'll send them later
Dodge has put out a revised seal for the 9.25 differential pinion.
Original P/N: 52070340AA
New P/N: 52070340AB
It may also be possible that there is a 'Secret Warranty'
(also known as Customer Satisfaction Program)
that DaimlerChrysler Area Service Representatives
may now be authorized to give payment for
if your out of warranty 9.25 differential has failed because of the poor life of the original
part number seal. This has been standard Chrysler practice in the past, but only if the
customer complains past the dealership and is armed with info and part numbers.
Thanks to HankL
Also from n8ech from the same site said
"This is the kind of repair that, if you are not familiar with it or do not have the tools, is better done by someone who does.
Better to pay a little more now and have a warranty, then not and end up with a bigger bill and/or being stranded."
The link for the tool
http://www.sjdiscounttools.com/otc6602.html
Good Luck
Old 05-21-2009, 01:52 PM
Rep:22
Good Luck
that tool is used to adjust the carrier side to side , which in turn would set backlash between the ring and pinion. to do the pinion bearing is alot more involved than carrier bearings. pinion depth is critical to bearing and ring and pinion wear , you must get your tooth contact just right or it will make alot of noise. you need .001" dial indicators and magnetic bases , torque wrenchs. i personally would ust pay the price to have it done , to do it right yourself you would spend more on the correct tools to do the job than a dodge dealer would charge you for the doing the job (and then you have a warranty also).
just my two cents.
Old 05-21-2009, 03:37 PM
DaSOB's Avatar
Rep:51
Thanks for all the input, gents. I have a service manual and it emphasizes that it is critical to get the bearing pre-load correct by torquing down on the crush washer just the right amount. I probably could do the work, but I'll let the pros handle it so that if something goes south, I'm not out another $100 for parts plus the PITA of re-doing it.
Rebhays27, you may have been called one, but I'm a card-carrying SOB!!
Thanks again!
Ah Luv Muh Truck!!
