Place your Ad Here!
Old 05-20-2009, 08:38 PM
dodgeramowner2002
Default Smell Antifreeze on Start-up
I have a 2002 dodge ram withe the 4.7 liter v8. it has 78K miles. I am losing approx 1/4 inch of antifreeze from the resevior a week. when I start the vehicle I smell antifreeze inthe engine compartment. It seems like I smell a little from the exhaust as well.(hard to tell) I see no antifreeze around the manifols or the heads. I am not losing any on the ground or overheating. is this a small crack in the head gasket or head that is to hard to see? is there anything else that this could be. the only thing I have done is replace the thermostat but there is no leakage around that. please help!
Old 05-20-2009, 11:03 PM
08quadram's Avatar
08quadram 08quadram is offline
Vehicle: 08 Ram Quad 1500
Color: silver
Rep:22
08quadram is on a distinguished road
If you are smelling it from the exhaust, you have either a cracked block, head, or blown head gasket. Easiest way to tell that is with a compression test. make sure all the cylinders are approx the same. If you have a cylinder with much less compression that the rest, that could be the problem. Also to a pressure test on the cooling system. It should hold 16 lbs or what ever the specification is. If it doesn't you have a leak. 1/4 of an inch isn't very much. I'd think if it was burning coolant, it would be more than that. My guess is a leak somewhere and after it warms up the engine heat causes it to evaporate.
Mike
'08 1500 Ram, Quad 4x4 Bighorn, Silver, 20" wheels, 5.7 Hemi/MDS, 3.92 axles
"Meddle not in the affairs of dragons, for thou art crunchy and good with catsup" -Doc, IFSJA
