Dodge Ram Decals
Old 05-22-2009, 12:30 AM
mattbacak3621
Default anyone else have this problem
i am having a whine in my trans or rear end when i am driving at 45 to 50 miles and house and also 75 to 80. if so has anyone taken care of it and what was the problem
Old 05-22-2009, 08:28 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
I know that this should be obvious, but I'm gonna ask anyway. Have you check the level of your tranny fluid? I had a similar problem in an old Ranger that was low on tranny fluid, after filling 'er back up, all was well.
It might also be the U-joint.
I'd take it in to get it checked out. Being as you have an '08 it'll still be covered.....
Exco
Bill
Old 05-22-2009, 09:26 AM
Rep:4206
I know with mine, when the pinion seal/yoke was going bad, it sounded like that, almost like a fuel pump going bad, had that fixed, re-filled with fluid, knock on wood, seems to have gone away, but I'm with ExCo on this, check the fluid level and have someone look at it.
Old 05-22-2009, 09:27 PM
BigDaddy112 BigDaddy112 is offline
Vehicle: 2003 Ram 1500 4.7L
Trim Level: Lone Star Edition
Rep:22
BigDaddy112 is on a distinguished road
i was having the same problem in my 03. when i went under the truck i noticed by the rear diff it seemed like alot of stuff had sprayed from the axle. it was coming from the pinion seal. had that replaced and flushed the whole rear end and tranny and it ran good as new. if your replacing the pinion seal yourself your guna need an impact wrench
