Old 03-19-2010, 06:48 PM
cb00ram cb00ram is offline
Vehicle: 2000 Dodge Ram
Trim Level: Quad Cab
cb00ram is on a distinguished road
Exclamation shaking
2000 1500 5.9 4x4
when im going down the road 50-60mph truck has a slight shake to it but when i increase speed it stops and it also when i let out of it it seems to diminish a little bit any one help me on this one?
Old 03-19-2010, 06:53 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I had a shake when I was going down the road too. But let off and would go away for a little bit.
I just got it back from the shop and it had new u-joints, brakes and rotors, and the main piece a wheel bearing was bad. But I think ball joints can give you that shake too, cause thats what I thought was wrong with mine till today.
Old 03-19-2010, 06:56 PM
Rep:2657
it could be several things
incorrect tire pressure
front end alignment
tire wear from bad shocks, check for cupping
bad tire, look for a bubble, usually in the side walls
others may come up with different ideas
Old 03-19-2010, 08:56 PM
RamTech RamTech is online now
Rep:1909
A vibration like that can be cause by anything that moves in the driveline and suspension. Start with the basics. When's the last time you had the tires balanced and were they just spin balanced or road force balanced?
Old 04-01-2010, 01:16 AM
ndgo88 ndgo88 is offline
Vehicle: 2004 Ram 1500 4.7 2WD
Trim Level: short bed QC
Color: Light Almond Pearl
ndgo88 is on a distinguished road
I had the same problem, though it was my rotors. I had original wrangler HP's on the rear and both were cupping and inside wear. Replace with Cooper HT plus. No more vibration.
