Old 05-27-2009, 09:07 PM
ReaperMarine51 ReaperMarine51 is offline
Vehicle: 2007 Ram 1500 4.7L 2wd
Rep:13
ReaperMarine51 is on a distinguished road
Default stack leveling kits
well i decided not to put on that body lift, but im still persistent on getting a couple more inches of lift out of the front of this truck. could i possibly put another coil spring spacer leveling kit on? I already have the 1.5" on the top, but could i possibly put another one on the bottom of the coil spring? if so would i need new shocks?
Old 05-27-2009, 10:41 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
Leveling kits are not expensive, I would suggest going and getting a 2.5" leveling spacer and doing it that way.
Old 05-27-2009, 11:14 PM
0212353 0212353 is offline
Vehicle: 2010 Dodge Ram 1500 Crew
Rep:91
0212353 will become famous soon enough
Send a message via AIM to 0212353 Send a message via MSN to 0212353
don't stack the kits......not a good idea.
Old 05-28-2009, 02:38 AM
Rep:13
I have the 07 2wd, it says that sometimes 2" or more kits will not work even though they say for 06-08. It says the only one that will fit for sure on all of them is the 1.5" which i have. Should I try to get the 2" one, or maybe try the 2.5" one for the megagcab only? what do you recommend, and why not stack another 1.5" one on the bottom? Is it dangerous or something?
Old 05-28-2009, 09:21 AM
Rep:91
2wds are a bit tricky!
I am not sure exactly what is out there for the 2wd guys (sizes), but I do know for sure that a megacab part will not work (megacabs are solid front axle). As for dangerous, well it sure can't be good. I won't do it.........
Old 05-28-2009, 10:21 AM
57Hemi08's Avatar
57Hemi08 57Hemi08 is offline
Vehicle: 2008 Dodge Ram
Trim Level: SLT Big Horn
Rep:42
57Hemi08 is on a distinguished road
I would just take the spacer out and save up and buy a spindle lift like http://performancelifts.com/cgi-bin/cart/CSSD1106.html and it will be much safer and better on the suspension than a spacer. Or here is a 2" spacer http://performancelifts.com/cgi-bin/cart/PLCDGU2.html
Old 06-12-2009, 01:56 AM
mxd909's Avatar
mxd909 mxd909 is offline
Vehicle: 2005 Dodge Ram 1500
mxd909 is on a distinguished road
just get the cst lift spindles its a whole lot better than the spacers.(i think it will fit the 07)
