Old 05-28-2009, 12:04 PM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
Default Better rear end gears
Hey everyone,
I have a 04 4.7 QC and was curious to find out what would happen if i put the rear diff gearing from another ram with a bigger engine like a 5.7 or even a srt10 rear end. Can it be done? If so will i see a differance in driveablilty. I dont tow anything but I do have all terain tires tires and my overall wheel height is 26" wheel and tire. I also have a CAI and flowmaster exhaust, I will be reprogramming the computer in the near future but lately i have been noticing a big drop in power. On the highway i cannot seem to get over 90 mph. obviously without ading a turbo or charger or nos what else can i do to bump up the power a tad bit more.
Any advice would be greatly appreciated.
jeff
Old 05-28-2009, 12:50 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Do you know what gears you have now? I have a 4.7 and it came with the 3.92 gears as part of the Big Horn Package.
Old 09-22-2009, 02:41 PM
Plainbroke Plainbroke is offline
Plainbroke is on a distinguished road
Curious what gears most run or think you should run to get better mileage, when towing light trailer and 1000lbs of stuff on it. Say 1500lbs total. Have 3.55 gears in rear now. was thinking with the extremely tall factory tires same height as a 31 10.5 x15 this truck is over geared even for highway mileage, with such a small V8. Sure it puts out great power numbers but at the cost of mileage..
Old 09-22-2009, 04:15 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
The gearing doesn't matter as long as it comes from or made for a Chrysler 9.25" Rear End. Hopefully by the end of the year I will have a DTT and 4.56's installed.
Don't Fear the Gear.
Old 09-22-2009, 04:55 PM
Vehicle: SRT-10
Rep:434
That's exactly what I'm about to get installed. I got the Motive 4.56 gear set, install kit, and DTT from Moe's. The install kit didn't come with ring gear bolts, however. I bought new bolts at the dealership. I don't think it is a good idea to re-use ring gear bolts. I am also going to install Lakewood traction bars. By the way, I have heard that on the '06 and newer 9.25" the 4.56 ring gear has case clearance problems that guys are fixing with a little grinding.
If you want to find out what gears you have from the factory there usually is a sticker on the inside of the glove box door that tells gear ratio and if it is limited slip.
Old 10-26-2009, 12:30 AM
MOOSEFIRE66's Avatar
MOOSEFIRE66 MOOSEFIRE66 is offline
Vehicle: 2002 Dodge ram 1500 4X4 4.7L
Trim Level: SLT ??
Color: Fire Truck Red Baby!
MOOSEFIRE66 is on a distinguished road
Also, my ram has a sticker around my front axle stating the gear installed. Probably does for most Rams also I would assume....
Aftermarket reverse lights, Emergency lights, New tires.......More to come!
Old 10-26-2009, 01:57 AM
AIR RAM's Avatar
AIR RAM AIR RAM is offline
Vehicle: 2002 4.7L QC RAM (9.49's 8th)
Color: SILVER
Rep:13
AIR RAM is on a distinguished road
A general rule of thumb we use is if your tires are 30" or taller then 4.56's would be the better choice of gear ratio. If your tires are 29" and shorter then 4.10's would be the better choice of gear ratio.
SPEED SAFE, AIR RAM
