02-08 Headlight Adjustment? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 05-31-2009, 02:23 PM
Danstona Danstona is offline
Vehicle: 2005 Dodge Ram 1500 4x4 5.7L
Trim Level: Hemi Sport
Rep:35
Danstona is on a distinguished road
Question 02-08 Headlight Adjustment?
The only adjustment I can see is to move the headlights horizontally... I have no vertical... I cant imagine that there isn't a vertical adjustment, but I just can't seem to find it.... I've looked all around the headlight.. Does anyone know where this is? Thx
Old 05-31-2009, 04:45 PM
jamesb0 jamesb0 is offline
Vehicle: 2006 Ram 2500 Quad/ SB / 4x4
Color: Flame red
Rep:57
jamesb0 will become famous soon enough
Thumbs up Vertical aim
This from the shop book
Rotate the headlamp vertical adjustment screw (2)
on the inboard side of each front lamp unit housing
Old 06-01-2009, 11:59 AM
Rep:35
So... where is the left right adjustment then? lol.... I definately thought that was the left right adjustment and not vertical.. it just looks to make more sense..
Old 06-01-2009, 09:44 PM
Color: Flame red
Rep:57
Default Screen shot of manual
Old 06-01-2009, 09:48 PM
Color: Flame red
Rep:57
Default Screen shoot text
Just incase you can't read it
HEADLAMP ALIGNMENT
NOTE: Due to the linear nature of the headlamp cutoff, a properly aimed low beam headlamp will project the
top edge of the high intensity pattern even with the headlamp horizontal reference line on the alignment
screen. No horizontal (right/left) adjustment is required for this headlamp beam pattern. The high beam pattern
will be correct when the low beams are properly aimed.
1. Turn the headlamps ON and select the Low
beams.
2. Rotate the headlamp vertical adjustment screw (2)
(1) to adjust the beam height as required.
Old 06-01-2009, 10:06 PM
Rep:35
Originally Posted by jamesb0 View Post
Here's a screen shoot of the manualAttachment 872
Thanks for that info. It helped me out... I adjusted them, and the PIAA's ... everything is great now.. except these crappy high beam bulbs on these lights just suck! lol... whatever they are they are brutal...
Old 02-13-2011, 06:18 PM
Madmax's Avatar
Madmax Madmax is offline
Vehicle: 2004 Dodge Ram 4x4 4.7L 5 spd
Madmax is on a distinguished road
Thanks I was having the same problem
"This nation will remain the land of the free only so long as it is the home of the brave"
Old 02-13-2011, 06:58 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
im glad you got it all figured out and set right bud
Old 03-24-2011, 03:31 AM
RT TT RT TT is offline
Vehicle: 2008 Ram 1500
Rep:46
RT TT is on a distinguished road
thanks for the info now i can adjust mine too
Old 03-25-2011, 03:35 AM
DodgeTomahawk's Avatar
DodgeTomahawk DodgeTomahawk is offline
Vehicle: 2002 Dodge Ram
Color: PVR
Rep:62
DodgeTomahawk will become famous soon enough
Try to soak the threaded section of the adjuster with pb blaster...i have seen people turn the adjuster after years of sitting and they break the plastic that holds the adjuster to the lamp.
"ITS MY WAY...MY WAY OR THE HIGHWAY"
