03 ,1500, 4.7 idols low and now wont start - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-01-2009, 09:39 PM
dkgwelch
Default 03 ,1500, 4.7 idols low and now wont start
My truck idoled funny for a week and would shut off when making turns or when the rpms get to low usually when braking. But then it would fire right back up.After that i turned the engine off one day and it wont start sounds like its not getting fuel.? any suggestions?
Old 06-01-2009, 09:41 PM
dkgwelch
Also if it is the fuel pump is it easier to remove the bed or drop the tank?
Old 06-01-2009, 09:45 PM
OTwoRam's Avatar
OTwoRam OTwoRam is offline
Vehicle: 2002 Dodge Ram Slt
Color: Charcoal
Rep:120
OTwoRam will become famous soon enoughOTwoRam will become famous soon enough
I always slide the bed back ust ause its easier to move the bed then drop the tank and lift it back up and you dont have to unhook all that stuff. When you find out whats wrong lemme know cause my 4.7 does the low idle and sometimes stalls
Old 06-01-2009, 09:50 PM
dkgwelch
how many bolts need to be romoved for that
Old 06-01-2009, 11:13 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
Most truck beds that I have removed have 6 bolts.
Old 06-02-2009, 04:32 PM
dkgwelch
So this morning I took the bed off the truck and replaced the fuel filter. It was really an easy job. The truck now starts and will idle, but after driving down the highway and slowing to stop it stalled. So the idle is still acting funny and cuts almost every time i brake to a stop ???? Any suggestions of what it might bed now...
Old 06-02-2009, 06:19 PM
OTwoRam's Avatar
Color: Charcoal
Rep:120
one of the other things on here people have said is that there is carbon build up on the valves, one of the other members suggested using seafoam and see if that helps to clear the engine out some, also try using a good carb cleaner on the tb
Old 06-02-2009, 06:23 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
I would replace all of the spark plugs/wires. SEAFOAM the engine (Fuel), change the oil to a lighter weight oil, clean the throttle body, PCV-Valve, and replace the air filter. If you do all of these things and it still wants to shut off then I would replace the O2 and Exhaust Gas Sensors. Make sure that there are no fuel leaks anywhere and that you do not have any fuel in the oil. Getting a compression check is a good idea and having the Dealership put her on the Computer and checking for Missfiring would be my last idea. If none of those work report back
Old 06-05-2009, 08:39 AM
dkgwelch
I will start with the oil change , air filter, and sea foam.
Old 06-05-2009, 10:58 PM
Magnum488's Avatar
Magnum488 Magnum488 is offline
Vehicle: 05 1500 4X4 Daytona
Trim Level: Daytona
Color: GoMango
Rep:13
Magnum488 is on a distinguished road
You should check the IAC (idle air control) valve. If it is gummed up it can stick and do some weird things to the idle! Or it can go bad, it's just an electric motor that moves a valve back and forth to let more or less air in, to adjust the idle speed as the computer tells it to.
12 Charger R/T R&T, Dynomax, Trinity, 180 stat
05 Daytona QC GoMango 4X4 Long tubes, Y-pipe, Airaid, NX 100 shot, Superchips
03 Durango's 4.7's 4X4's SLT one white one green
95 Ram 1500 4X4 MP computer, shift kit, more..
idols low, stalling
