Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram – 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 06-02-2009, 12:49 PM
sboutilier sboutilier is offline
sboutilier is on a distinguished road
Default drop in oil pressure
I have a 1996 5.2. I will start the engine and let it warm up.It will run for about 10 minutes and the oil light comes on. Then about a minute later the oil pressure drops to zero. If I increase the idle speed it will be fine and when I let off the throttle it does the same thing. I have replaced the oil pump and the sending unit.
Old 06-05-2009, 11:49 AM
tyler
Default change ur oil and try some lucas oil stabilizer
Old 02-10-2011, 11:15 AM
Widowmaker Widowmaker is offline
Vehicle: 1996 dodge ram sport
Widowmaker is on a distinguished road
i have a 1996 too this is normal at idle it will go to zero then tap the gas it will go up. as i found out and been hearing its normal for these dodge's to do that just keep checking ur oil once awhile to make sure its nothing bad
Old 02-11-2011, 07:07 PM
sinned sinned is offline
Vehicle: 2011 Dodge Ram
Rep:5
sinned is an unknown quantity at this point
Check the oil pressure sending unit…common failure item.
If you find yourself in a fair fight, your tactics suck.
Old 02-14-2011, 08:46 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
my brothers truck had the same problem for a hole year the truck was fine, its your oil pressure sending unit.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 02-15-2011, 07:31 PM
i bought a new unit and still does the same thing but i have no problems
Old 02-17-2011, 08:38 AM
98redbull2's Avatar
Rep:52
i cleaned my brothers out when we had the intake off and it worked for 5 minutes and started doin the same thing so idk lol.
Old 02-22-2011, 07:29 PM
St. Ram's Avatar
St. Ram St. Ram is offline
Vehicle: 1997 Dodge Ram
Trim Level: SLT Laramie
St. Ram is on a distinguished road
I have a 97. It shows low pressure (not zero) but runs fine. When I give it gas, it shows correctly. Weird
